POF L'Amarante Corvette de 12 canons 1744 1:36 (Ancre Monograph- Gérard Delacroix) By Shota
Thank you very much dear Roger, I am doing my best to progress and learn professional skills. Your support and that of the other members is motivating and encouraging
I totally agree with Uwe. It’s a pleasure to see your progress and consistently good work Shota.
my dear friends
I am happy to update that thanks to Tobias's guidance and the encouragement from my friends I was able to produce beam h.
I promise in the next update to bring a detail of the process that is slightly different (I had a broad pear wood).
I have yet to apply the process to the second/parallel h-beam
I didn't take a walk/photograph because I wasn't sure I would succeed and I was more focused on work.
Thanks to everyone for the support with likes, smileys and words of encouragement
20240708_190237.jpg20240708_190254.jpg20240708_190428.jpg20240708_190502.jpg20240708_190733.jpg
good evening dear friends
As I promised, I will explain the working method I applied in creating the side h-beams/in slope.
First step, I drew on two separate boards (2.2 cm and 1.1 cm) the side shape of the beams.
After that I sawed and sanded until I got a good initial result of the contours. After that I sketched the front and back shape of the beams , and here too I sawed and sanded accordingly.
After receiving the two parts that make up the h beam, I made additional tests and adjustments/cutting/sanding and only after I achieved the required standard did I glue them. Even after gluing, I left enough raw material to allow me to make final finishes until I get satisfactory results that match the plan. Hope the pictures will help in understanding those coming in line
Good night everyone
20240709_192406.jpg20240709_192719.jpg20240709_193040.jpg20240709_193229.jpg20240709_193244.jpg20240709_194454.jpg20240709_195253.jpg20240709_200355.jpg
Witaj
Pięknie Shoto to zrobiłeś, oglądam twoją relację z przyjemnością . Pozdrawiam Mirek
Hello
You did it beautifully, Shoto, I'm watching your report with pleasure. Regards, Mirek
Hello dear friends
Tonight I spent several hours creating the opening for the steering wheel of the ship, which consists of 3 parts (i j k) and is located in the center between the pair of beams f. First I sawed the shape of the three parts. indicates that both sides (i k) are 5.4 mm wide and j is 7 mm wide.
I sanded the parts and then glued them.
Later I sanded again the flaky structure created from the 3 parts to produce a nice finish .
In the next step, I created the elliptical opening with a width of 16 mm. After that, I removed the lower remainder of part j. As a result, the sides of the circle at the narrow points tended to break. To prevent the break, I glued an outer layer 0.35 mm thick on each side from pear wood and a rounded piece with a length of 5 mm on the inner side to strengthen the weak points.
I sanded the bonding areas of the reinforcement parts a lot, to reduce the possible damage to the beauty of the part.
Don't worry, the width of the part will be adjusted to the other beams and their dimensions using adjusted sanding.
I believe the pictures will help in understanding the method
Good night everyone
Screenshot_20240712_013952_Chrome.jpg20240711_203328.jpg20240711_220922.jpg20240711_220927.jpg20240711_220951.jpg20240711_222800.jpg20240711_222809.jpg20240711_222819.jpg20240711_224929.jpg20240711_224937.jpg20240711_225051.jpg20240711_234344.jpg20240711_234406.jpg20240712_010906.jpg20240712_011024.jpg20240712_011121.jpg20240712_011743.jpg20240712_011806.jpg
Outstanding Shota! How your skills continue to grow!
I agree with Paul in the above post, but please pay attention to the symmetry: the right side is narrow to the left side. (blue lines)
my dear friends
thank you very much for your kind words and compliments
Jim my friend, it's just the angle the photo was taken that make the un symmetry
Hello Shota, my friend, I have once again taken the time to look in on you. It's just great what you're doing, looks very good, you can tell you really enjoy building scratch.enjoy building scratch.
Dear Adi
thanks for your kind words, I'm happy that you liked my work :) I'm very enjoy building scratch because I'm filling the creation process In my In my hands and in my mind
