Next step was one I was dreading...assembly and placement of the dewatering pumps.
First, I filed and then used a micro chisel to cut out the holes for the pumps.
Next the pumps were inserted through these holes. The tolerances were such that I had to add the simulated "black metal bands" AFTER sliding the pumps through the holes
Finally, the two sections were glued together, using shims and blocks to ensure they were parallel/straight.
Around this time, the dreaded French Shipyard Superintendent appeared. Again, the inspector has to explain to Midshipman Newbee that Seaman Brutis "fixed" the height of the pumps. The ones the Midshipman installed, from the kit were several mm too tall. Below shows the proper heights from drawings by Boudroit, so the men aren't pushing/pulling pumps OVER their heads!
The final two pictures show the pumps from overhead and the last one with all the pumps stained, cut to the correct height, with the small pieces for the pump handles installed.
The kit does not show or discuss the outlet from the pump. I'll have to check previous build logs to get some ideas on how to simulate the outlet for the water to shoot out onto the deck.
Thanks for your continued interest!
. Sorry man the WiFi in Cape Town is on “African time”……driving me nuts. Cheers Grant
