Great work - when ever you need some additional income, you could easily start a new business .......@Uwek
Hello Uwe,
what do you think?
Of course I didn't buy the hooks.
I made master models for the hooks out of brass and then had them cast in a jewelry foundry using the lost wax process.
You metal work is from the same outstanding level as you rope work, Johann. A pleasure for the eyes!@pianoforte
@Mirek
@Uwek
Thank you very much for your interest and the nice comments.
Also many thanks to all for the LIKES.
Continuation: Peak halyard - Drisse de pic
The peak halyard of the French corvette led over a double block with iron fittings and was probably hooked to an eyebolt on the cap des mizzen mast, similar to a depiction in the Atlas du Génie Maritime.
Source: Atlas du Génie Maritime - detail
I made the double block with a length of approx. 4 mm in the usual method from service tree. The fittings were made in the manner already described from partially prefabricated etched and cast brass parts. The hard soldering of the hook is a tricky job, but I've managed it in the meantime with some practice. The biggest problem is destroying the part with too much heat from the torch.
After adjusting the fitting to the block and soldering in the hook, the solder joint was sanded clean.
The next two pictures show the finished double block with the eyebolt, which will later be attached to the cap.
And last but not least, a picture of the hooked double block.
Now there are still a number of different blocks to be made for the gaff and the boom.
To be continued ...
Johann, thank you for your answer, I almost thought so. I used it undiluted on the inside of Le Rochefort and the result was not satisfactory, I also treated it with steel wool. The result is better than with the sanding primer from Clou but it doesn't look as good as it does on your model. I ordered the thinner on Saturday because there is no hardware store nearby and I hope it will arrive before the holidays. I also tried oil and it looks very good, but the dust sticks to it and that is really annoying.Hello Tobias,
I'm glad you like it.
I use the bale matting from Clou undiluted. After applying it, I always sand the surface with extremely fine steel wool so that it doesn't shine. I repeat this process more often, depending on the component.
I know that the majority of model builders prefer oil. But I also go my own way with the material for the rigging...![]()
This is not the Proxxon MF70, but a normal drill stand from Proxxon MB 140/S MICROMOT, so nothing special.
I have a question about the item on left, that looks like a bobbin with post and ropes, what was purpose of this item? Looks like a floating bobber to assist someone in the water? Or an anchor Bouey?
