She looks great! If I may suggest a fw coats of sanding sealer before the painting will result in a much smoother paint application.
Rob
I was going to go with the suggestion from the instructions and use a spray primer. I have some handy.
Rob
That should work!I was going to go with the suggestion from the instructions and use a spray primer. I have some handy.
Yes it is an option.RD- Looking good- and this just came into my mail at the perfect time! I just received MY kit today in the mail!
The first thing noted- is that there were TWO bottoms provided- one in a solid piece- and one in 3 longitudinal pieces- to glue together!
Can anyone advise what the deal with that is? They're both on the same board... is it an option to avoid having to glue the 3 pieces together???
I just hope mine looks as good as yours!
One piece is easier but three-piece construction is more accurate. Since plywood was not yet available during the hay day of the Bank dory, the bottom of a dory had to be made up of individual planks. If the boatbuilder had access to wide pine boards, a bottom could be made of three planks. If the boards were narrower, it might require five planks. Fair winds!I did figure out the 2 bottoms were to have a choice to assemble the 3 pieces- which is what I did- or use a one- piece bottom.
Your boat looks great for that gap just put in a small strip of wood, sand it flat to the rail cap and paint it.I've got the cap rails primed and painted. I'm not going to start glueing until I figure out how to deal with the gap at the stem end.
Brother Betz:You are mistaken. According to the instructions, the breast hook belongs at the level of the gunwales; it "unites them inside the bow." I did trim the frame too aggressively so the gunwales are lower than they should be.
