Every (half) hold has a hatch: 2 rows of 9 hatches. Also for the net holds: 2 hatches.Hi Peter,
Is every barrel hold getting it own hatch? Or is there a passage between the holes below deck?
Or you can use a tapered dowel that you wedge inside.I can now do a bit of 'production' painting the barrels:
First cleaned them all. Luckily I found my 4-finger gripper in time. It's much easier to paint. After the painting (3 layers) with the brush pen I just have to clamp them in the lathe for the hoops.
By pressing the top with its inner spring the 4 fingers come out. By releasing the inner spring grabs them.
O yes, but I have to buy or make that …….Or you can use a tapered dowel that you wedge inside.![]()
! Thanks for the overview image with the walls in place. Just wonderful modeling!Thanks, Stephan. Made the decision to split the hull in a split second. Luckily not a split personality. Just a bit pleasantly disturbed …..Back in 2023
you made a good decision splitting the ship in half. I can look for hours to the details you make on the inside.BALDER, Vlaardingen Herring Lugger from 1912, scratch build scale 1:50 Plate-On-Frame
He got a green mat, for sure. See post #3 WYSIWYGshipsofscale.com
Thanks, Paul. Glad a made this decision…… particularly for you ….Wow! I finally understand what is happening! Thanks for the overview image with the walls in place. Just wonderful modeling!
Thanks for your compliments, Dean. In my head I am many steps ahead and already building up the deck with the planking with hatches and the masts with the partly split rigging. But building the inside is also great fun. After placing all the barrels I can satisfy the captain and helmsman with their accommodation. Then building 3 stoves, a Donkey steam kettle etc etc.Peter,
She looks beautiful, and as people have mentioned, it’s great to see all the details of the interior. You have definitely created a model that is worthy of display and admiration. I look forward to seeing the eventual completion. For now, I enjoy watching it go together.
Dear PeterStarted with the rest of the beams:
First I made the 5 beams in the left hold (9), fitted them with the knees and placed them at the height of the 5 barrels. Dry-fit and layer by layer I will further align and secure them.
Now I will apply the beams layer by layer and align them between holds 2 and 9. For this I have stretched a thin elastic line on the underside of the beams.
The remaining 6 beams were made to size and first placed dry-fit between the U-profiles:
Then I placed small dots of glue under the knees in the U-profiles and then slide the beams into position.
Thanks, Shota. It’s sometimes exploring new boundaries.Dear Peter
you are doing incredible things on this wonderful ship model
Good morning Peter. Wow. Keep all those details coming….she just gets better and better. What an inspiration this model is. Cheers GrantStarted with the rest of the beams:
Thanks, Grant. And the constant research is paying off ......... see below ......Good morning Peter. Wow. Keep all those details coming….she just gets better and better. What an inspiration this model is. Cheers Grant
