Thanks Maarten, the teeth are smaller then the cutter and real difficult not to mess up.Great small lion Stephan. The teeth are really fantastic.
Thanks Johann, great compliment of a master model shipbuilder.Hello Stephan,
Now that you have finished your lion figure, I have to give you another big compliment. And you can be very proud of the work of art, all carved by yourself from a wonderful material: Wood ... Boxwood?
The small branches you see in the decoration where between 1,5 and 2 mm. That is for castello to small and that will break. If you tape it to a piece of wood it is workable but this ornament has a 2 sided view. So I started over with boxwood.Now you have me worried, Stephan. I have mountains of leftover castello boxwood that I was hoping to use for carving the decorations.
I don't think I've ever seen European boxwood available anymore. I'll poke around some more.The small branches you see in the decoration where between 1,5 and 2 mm. That is for castello to small and that will break. If you tape it to a piece of wood it is workable but this ornament has a 2 sided view. So I started over with boxwood.
If you can buy European boxwood (Ebay), just buy it. It is much better to use.
Very nice ‘artisanal 3D’ carving, Stephan.Almost forget to post my work on the HZ.
I'm working on the "zitters", it takes time I can make only 2 (one on each side) and have to wait to the glue to dry. But it goes steady.
View attachment 504101View attachment 504102
I also make the lion fit correct on the bow and started with the decoration behind the lion. The first try (thought it was boxwood, but it seems to be castello and on the small parts it breaks to easily) was no success, the second one with real boxwood goes better. But it is more work then the lion. It is very small and breaking on the smaller parts is possible. I used my MF70 to drill straight the holes.
View attachment 504103View attachment 504104View attachment 504105View attachment 504106View attachment 504108View attachment 504109
Thanks Peter.Very nice ‘artisanal 3D’ carving, Stephan.
Most probably too high import taxes on theseI don't think I've ever seen European boxwood available anymore. I'll poke around some more.
Me too. But it is kind a job like ratlines or making cannons for the Victory. BoringHi Stephan,
Good to see you back on the hull.
25% extraMost probably too high import taxes on these![]()
Lets call it American Boxwood, what a beautiful name.25% extra![]()
MABA: Make American Boxwood Affordable.Lets call it American Boxwood, what a beautiful name.
DittoHi Stephan,
A very nice ornament, Stephan. And the lions tail kept it nicely in place.Thanks Grant. And everybody thanks for the visit an likes (and fun)
Today’s update.
This was no fun I can tell you, my "tiny"fingers find it difficult to hold it while using the drill. So it was a few time airborne.
But I succeeded to finish the ornament in the bow. Still don't know how to call that part, need to lookup. Everything isn't glued. There is another part I need to make and that is the top of that piece of wood on the back of the lion. There comes also a curl in. I fit and glued also 4 "zitters" in the hull. The pictures:
View attachment 504411View attachment 504412View attachment 504413View attachment 504414View attachment 504415
European boxwood is great to work with
