- Sep 10, 2024
No - not me - Brad. And I meant that in the most loving of ways.Sorry Russ, I wish I had seen your pics earlier, and I hope you are not too mad at me........
Hi Paul,The iron ingots were offloaded to be used for forging and new cargo in barrels has been loaded for the trip back home.
!Thank you Grant. Appreciate your feedback!Hi Brad. Gravel or iron ballast , your cross section is brilliant. Way to go. Cheers Grant
Hi Brad. What a pleasure. Maybe “when I am big” I can sell the business and follow your example. Looks awesome. Cheers GrantThank you Grant. Appreciate your feedback!
Unfortunately, the mobile shipyard is currently at all stop. Waiting for more barrel kits from Ali Express. I also underestimated the amount of lumber needed to make the launching ways, so waiting for Son-in-Law to bring a resupply.
In the meantime, workers are relaxing and enjoying the Spring Skiing in Colorado!
Kurt,Another tip to any sailor planning to add gravel ballast.
When you have it in final place, soak with Isopropyl Alcohol to "wet" all the ballast, if not done, the glue may only attach to the top of pile and not soak down thru, this leaves a thin crust on top of ballast and if bumped, the loose gravel underneath can come loose.
This happened to me several times while trying to lay and glue ballast on sides of my model railroad trackwork. I finally learned the lesson the hard way.
Much easier to do right the first time then have to clean up and re-due the project.
A lot of fun there up on the mountains, Brad.Finally, the medium barrels from AliExpress arrived at the campground.
B U T . . . Shipyard progress was delayed by several days of fresh Breckenridge powder. Photo1.
Today, the ski legs needed a break, so Brutis assembled, then stained 12 medium and 10 small barrels.
B U T . . . In photo 2, Ens Newbie had to tell the shipyard Superintendent that he forgot the black banding material, so cooperage work is again....ALL STOP.
Friday, mobile shipyard will move from 9,500ft to the basement at 5300ft, where work should begin again.
View attachment 509426View attachment 509427
Is that a box of marshmallows?
You wouldn't what him kneading dough on the floor, so he did need those tables.Petty Officer Brutis decided to build two tables for the Cook.
He placed the first by the bread side of the oven and the other by the roasting hearth.
View attachment 509801 View attachment 509800
Maybe some good hardtack biscuits for use if the cook gets sick.Nah - the scale's off - toilet paper maybe? Did they have TP back then - probably not. Ok, I go with marshmallows.
