Good evening, all, two layers of 1mm pear planking has solved my nose gap problem. Its ugly at first but gets better check it out.
After some preliminary sanding and dry fitting, the gap is filled.
A little more honing will be required along the bow stem slot and with a complete hull covering on one side, I will have to come up with a clever covering along the open side at the bow only.
Looking under the jig top it appears there is too much gap between the ribs and the bearding line however according to the plan drawings there is a significant gap so this all is going to work out well.
Only 70 more frames to go. Thanks for stopping by.
Till next time!
Till next time!
. Cheers Grant
