@RussF
I managed to use Pavel's "clamps", but not the way he intended
Those four spots were one of those "PIA" things. The binder clips were fine holdingt the strake in place, but there was just enough "spring" to lift the back edge away from the frame. So there was an AL-FI moment.
Jan
Good evening Jan. What we come up with to make these models…… without our AL-FI moments we would all be more insane than we already are.@RussF
Jan
Cheers GrantYessir, I have to agree with you. I think that method will be repeated a few times as the build continues.Good evening Jan. What we come up with to make these models…… without our AL-FI moments we would all be more insane than we already are.Cheers Grant
AL-FI is a @Peter Voogt term/expression from when he was working on his Bluenose build. I'm sure he will chime in and explain the concept. In short it's going way beyond thinking outside the box while trying to solve a pesky problem. His Bluenose and Robert E Lee build logs are fascinating to follow.AL-FI ???![]()
Looks great Jan!I'm up to plank #4, on one side and wondering how far you planked both sides before starting to work on the deck pieces. I can't tell where Pavel stopped planking before working on the decks.
Her it is, but it’s also Dean’s @Dean62AL-FI is a @Peter Voogt term/expression from when he was working on his Bluenose build. I'm sure he will chime in and explain the concept. In short it's going way beyond thinking outside the box while trying to solve a pesky problem. His Bluenose and Robert E Lee build logs are fascinating to follow.
Jan
AL = Artistic License
FI = Free Interpretation
To be used when there is no original documentation. Then AL-LF is looking over your shoulder and says it alright.
Excellent, I've got one side to strake #4, now working on the opposite side to get to strake #4, then I'll copy your method and alternate sides to get to strake #9.Looks great Jan!
I alternated sides with each strake. That way I could let one side dry while I worked on the other. On good days, I could get 2 or 3 rows on each side. Pavel and I (following his video lead) stopped after installing strake 9, before adding the meginhufr (strake 10). Working on the deck boards now (just got all the treenail holes drilled). The deck boards (with the little sliver extensions attached to the ends) are just slightly wider than the beam, which is good, because you can then accurately trim/sand them to get a good fit to the strakes.
Looking very cool Jan. Nice!@RussF
Jan
I drilled 4 ea 0.8mm holes in each board for treenails (except some boards near the outer ends of each room only had 2 or 3). I used the engraved rings as a guide, but I stayed toward the center (widthwise) of the board, but still within the ring (hope that's clear). I plan on putting the double bead profile along each long edge, and I wanted to make sure my treenails were far enough away from that edge so as not to run into the profile. I'm going to have to fabricate a holder for my scratch stock 'cause that's a lot of boards! (Why do we do these things to our selves?) My fingers would easily start cramping while profiling the strakes. My boards will be installed with the engraving down. I have never liked the look of simulated treenails by laser engraving them.BTW, how many holes did you drill in the deck boards???
Hi Jan,
I started at the keel and worked my way up, beveling both up and in. It's a good starting place, but you will find as you start adding strakes that these notches will need to be trimmed. I don't think they will every fit perfectly. The fit to the strakes amidships is much better than toward the stems. I pretty much gave up on trying to make them fit perfectly, as long as you have some surface to glue to. They will be covered anyway.
Looking good Jan!
That's weird, both of you got your kits at least a week or two before me. My serial # is 57, maybe he's counting backwards.Yes, I have 2 flats each of ribs/bases, staves and bands and 1 flat of tops. The instructions, however, leave a little something to be desired. Sort of, "Here are the parts, here is what you make from them - you figure it out!"I think he was getting tired of drawing by the time he got to this point.
BTW Jan, I ordered and received my kit before you, yet my serial # is 68 and yours is 61. Not fair!I guess they're not sent out in order.
He probably stacked them up in the order that he packaged them, then drew from the top of the stack as he shipped them out. Some lucky person is going to get #1 pretty soon!That's weird, both of you got your kits at least a week or two before me. My serial # is 57, maybe he's counting backwards.![]()
