Hi, I used 220 and 320 grit sand paper and a lot patience.Jan. How did you get these parts so clean from the laser burn?
Thank for following my build. You've probably noticed that I don't work very fast, but then again there are many pieces that require preparation time before being added to the hull.Hi Jan. I'm following your build and do consider it to be very impressive work you're doing. I'm perhaps learning from you. I ordered the kit 1 month ago and still await delivery. I saw your note about staining the hull in oak. I also ordered the stains from Pavel as I did not know the colour to use. Where I live, its difficult to find model material and ever good wood dyes. I am concered that when I begin the build there may remain PTV spots that don't take the stain. I've condideted staining before the application of strakes. Best of luck there Jan.
Hello Ashley, I'm looking forward to seeing you start a build log. I think you will find that the kit will keep you busy for a quite some time. You will need to stock up on sandpaper, there is a lot of char that needs to be removed. I've used up many sheets of 220 grit.
Jan
I have some large "Tongue Suppressors" that I've covered with 220 and 320 grit. Pavel seems to have some nifty double sided sanding boards.Agreed. I use large craft sticks to make my own "emery boards" by gluing sandpaper to them.
I've been making my own sanding sticks as well, they work great. I also use single edge razor blades to scrape off some of the char marks on the faces of the strakes, it works well getting most of the big stuff off before I finish sanding them.I have some large "Tongue Suppressors" that I've covered with 220 and 320 grit. Pavel seems to have some nifty double sided sanding boards.
Jan
Wow Jan you've gotten a lot done, it really looks great! I'm looking forward to starting on the deck but at the rate I'm going that might not be for several months. LOLThe start of the decks.
The build plans,
Plus this video "Video #11 decking. There are steps that Pavel completes that aren't in the kits build plan.
But before I started separating the pieces from the flats, I flipped the flat over and numbered the pieces on the back.
I didn't want take a chance of mixing any of the pieces.
The assembly process. Remove the char.
Then butt the pieces up against a straight edge and glue them in sets.
The final glue up.
The finished deck.
Sorry for the glare from the wax paper, but it's a great backing since PVA won't stick to it.
Jan
Slow but sure is also good.Wow Jan you've gotten a lot done, it really looks great! I'm looking forward to starting on the deck but at the rate I'm going that might not be for several months. LOL
Steve
A nice and solid start of the deck parts, Jan. A lot of work but the outcome looks good.The start of the decks.
The build plans,
The final glue up.
The finished deck.
Jan
Thanik you, there are definitely a few parts. I've found that after gluing the bigger sections that I need to put some weight on them as the glue sets to keep them from warping.A nice and solid start of the deck parts, Jan. A lot of work but the outcome looks good.
Hi Jan, that's funny.This photo looks like the ship came to a sudden stop.![]()
That is exiting news.I think you will like working on the kit.That's brilliant progress Jan. It's starting to look much more like the completed model. I enquired when my kit may be dispatched. It's been 5 or 6 weeks since my order. I was informed it would posted out this next Monday. So maybe another 2 weeks from the Ukraine.
Mast and Spar Pavel Oseberg video #20.
@RussF
What is the "dimple " in the spar that Pavel is working on??
I see no reference for that in the build instructions or any of the plans. I've finished the mast and started on the spar when I decided to another look at this video and ????
Jan
