did you apply the clearcoat to the copper plates as well? I was wondering about that for my boat too.After taking off the Tamyia tape and allowing everything to "set" overnight. I wiped the coppering off with some alcohol to remove any fingerprints and grease then I airbrushed the hull and the cradle for the Constitution with 2 coats of Model Master clear coat enamel.
Yes the copper plates were also coated. If you want to "age" the copper you should do so before you coat it. You can also use a matt spray or Dullcoat on the plates instead to tone down the shine.did you apply the clearcoat to the copper plates as well? I was wondering about that for my boat too.
tksYes the copper plates were also coated. If you want to "age" the copper you should do so before you coat it. You can also use a matt spray or Dullcoat on the plates instead to tone down the shine.
Here is a comparison of the 3 blocks. The ones on the left are the blocks supplied with the kit. The middle blocks are Model Expo's "Beautiful Blocks" the one on the right are the 3D printed blocks produced by Syren models.
They both look great. The holes for the lines are very small and to use the same diameter lines I have had to drill out both sets of blocks. They handle about the same IMHO. I will certainly be buying more of them. I believe the beautiful blocks are produced in Italy and the Syren are made in the USA.Hi Rob,
What is your opinion between the "Beautiful Blocks" and the 3D Syren blocks? Dry-Dock Models do what looks like a very similar block to the Model Shipways ones and I found them very good. You are making a great job of this build and I am looking forward to seeing the finished article.
Regards JJ..
I can see many uses for that tool. I find my dremmel too powerful to sand things like this, even though it has a variable speed.Next up is the fife rail. There are 5 stanchions that are laser cut and they want you to round the middle portion. the one end has been laser cut into very thin slices, I believe to represent sheaves. They recommend to treat these with CA to harden the wood. I think it would have made more sense not to cut these slots but to represent them with thin pencil or sharpie lines. But it is what it is. Besides rounding the stanchions, you also need to remove all the char since they want these pieces stained a natural wood color.
Instead of files I decided to try the nail drill I bought for $10. besides the miniature drum sander, it also has other bits that appear to be small diamond burrs of various shaves.
I am using the bit you see to slowly round the center portion and remove the char. IT seems to work fairly well doing both. The small size allows you great control over it's actions.
