As I mentioned a moment ago, I was in a weird place where I was not going to post a build report. The reasons are complicated – but basically, I was finding myself annoyed by several individuals (a small group?) on the forum. Self-righteousness is always unattractive in my book, so I found the forum draining rather than life-giving.
On the other hand – there are some truly remarkable fellow modelers on the forum, so I’ll do my best to lean into those friends rather than allowing the others to take the joy out of my participation.
All this to say that the model has been on my workbench for a while now and I have not been diligent in taking pictures. The smattering that I have will have to suffice.
The Ancre monograph is epic in its breadth. But for those familiar with it you will understand it when I say that there are some difficulties. Perhaps the single most vexing is that Mr. Lemineur argues that the frames were not perpendicular to the keel – they tip ‘forward’ about 1.2 or 1.3 degrees. As you might expect, that makes the drawings uncharacteristically difficult to interpret.
At first I thought to simply ignore this feature – but eventually I decided that would be unwise. The construction solution is rather simple – but every time I look at a drawing it gives me a headache.
The one significant departure that I am taking (sorry
@NMBROOK) is the way the frame pairs are joined. The Saint Philippe has morticed frames. Here are a few images from Nigel's build showing what I am talking about:
The purpose of these mortices was to lessen the tendency of the ship to hog (the bow and stern are less buoyant by volume, so they sag into the water).
I have chosen to ignore this distinctive feature of the SP. You might argue that omitting the mortices is tantamount to no longer building Le Saint Philippe. But I am fully planking the exterior so the mortices would not even be visible there. The interior of the framing WILL be visible – but is the added complication of morticed frame pairs justified for the little bit it would be visible on the inside of the hull? I have decided it would not be. My apologies to the historical purists.
In true scratch building form, I began with rough cut lumber. This is European pearwood purchased at great cost
After some head-scratching I figured out how to use some of my shop tools to turn these into dimensional billets:
I chose to begin with the frames. For this stern section model I decided to build 15 frame pairs (30 single frames) in the typical manner. You know how it goes:
Here is the size of an SP frame compared to the Kingfisher (both are 1:48 scale):
The obligatory picture of a stack of rough frames:
For the Kingfisher I installed these frames in a build jig and commenced with the sanding/shaping. Here I chose to add some provisional bevels based on the frame drawings. I left some extra on the frames, but I won’t know if I left enough until it comes time for the final shaping...
The Kattner sanding center:
My thanks for your interest!
