Hi Y.T,Construction design? Two long wood screws in each of 8 corners with some wood glue.
No. It would be too expensive and not necessary at this time. Most important to me is just to protect it from grease and dust. Besides a display case with glass or even a plexiglass would be around a thousand dollars. See no point. I am the only one to look at this model. No one to show it to.Are you intending on making a proper display case
I am guessing that you are going to use some clear or translucent plastic over your frame?No. It would be too expensive and not necessary at this time. Most important to me is just to protect it from grease and dust. Besides a display case with glass or even a plexiglass would be around a thousand dollars. See no point. I am the only one to look at this model. No one to show it to.
Yes. This is what I plan to use.I am guessing that you are going to use some clear or translucent plastic over your frame?
Looks Better than the Caldercraft Model J.T.!
Visited these gardens a few years ago. I agree, they are very much worth the visit. It would have been quite easy to wander around there all day.This is a place worth to visit.
