Gary,Thanks Rick,
That made my nerves relax a bit. I was thinking that once you slice into the drawings with a pair of scissors, your chance of proofing is lost. Did you copy it on your home scanner or a specialized printing service?
Anyway, I have a few questions about your model, and if you cannot answer here, you can always private message me.
Question 1: Did you experience any warping or narrowing of the hull once you cut it away from what I call the "Lofting Plate"?
Question 2: Have you or any other model shipbuilders watched the video I found on the net, and what are your Impressions about it?
. Are there any videos on SOS showing a similar method and or improvement to Harold Hahn's method?
Regarding Question 2, I noticed that when he places the Body Plan on each end (I assume), the opposite end Body Plan would need to be printed in an inverted orientation. Is that possible?
I am sure Dave from the Lumberyard could help us all out in this field.
Regards
Gary
Ask as many questioned as needed, search and read other build threads. Your choice of a starting kit is important. When I started my first plank on frame this forum guided me to the Caustic by Dave. His step by step videos help immensely .
I used my home printer/ scanner. I aligned each framing unit at center of printer glass plate for photocopy.
Question 1. I didn’t notice any issues as mentioned.
Question 2. I havent seen this video. I’ll give it a look. . For your build you may find it beneficial to add control points that assist you.
