The Norske Love" by Noël Luc Build log
I like the progress of your assembly, very accurate and neat. However, if you don't mind, I think the gun rigging is slightly off your nice ship. Despite the rigging blocks and rigging ropes are out of scale, you have used the blocks incorrectly. I think rigging a gun, specifically on a small scale, is a challenging task so they look OK. Sometimes, I don't even bother to fully rig the guns, and use the breeching line only. This should be a much better appearance compared to an oversized or incorrect rigging, IMHO
Again, I hope you don't mind the critics, as I understand how much time you've spent rigging those guns.
Hi Jimsky, don't worry that I can't handle criticism!! I don't see this as criticism, I see this as help for making a nice and well made scale model! This is my first ship and I knew in advance that I would make mistakes! Good that there are people who help me prevent or correct these mistakes! Earlier in my build log I mentioned that my wife helped me with the rigging! It won't be pleasant if I tell her that I gave the wrong scale of blocks and ropes (oops)!! She did indeed work on that for days!
The blocks are 7mm long, if I multiply that by the scale of the model 1/75 then I get 525mm this is more than half a meter or about 20.66 inch. I don't know how big the blocks are on a real ship but this seems way too big to me! I should have made this calculation in advance!
Now the question is what I'm going to do. I have already searched on the internet for many pictures of model ships and some of them also had cannons where many blocks and ropes of the cannons were very close to each other and that is indeed not so nice and too much!
When the time comes that I will mount the cannons on the ship I will see how it looks and if that is not ok then I will remove the ropes! I hope with that decision my marriage will still stand! (joke)!
Can you tell me what "breeching" is? and what you want to say with IMHO?
I am glad you've responded to my post and treated it more as help rather than criticism.
IMHO (In My Humble Opinion)
In the Navy, "breeching ropes" refers to a sturdy rope used to control the recoil of a cannon on a ship by attaching it to the gun's rearmost part (cascabel) and securing it to the ship's structure, essentially preventing the gun from flying backward after firing; essentially acting as a brake against the recoil force during firing on a historic naval vessel.
Key points about breeching ropes:
  • Function: To restrain the backward movement of a cannon after firing.
  • Attachment point: The rope is typically wrapped around the "cascabel," the knob at the rear of the cannon barrel.
  • Historical context: Primarily used on sailing ships with large cannons, where managing recoil was crucial.
Check this out:
Here are some photos from the model made by Dan our member @dafi
Hope the provided information will help a bit, and should keep you busy for quite some time reading & learning ;)
Hello everyone, I have started to finish the railings of the ship! That is not so easy! I use a lot of the pictures of Dean62 to see how I would do this best! The pieces I need for that are in the kit but I could not use them. So I went looking for the necessary planks of the right width and thickness myself!
The pictures show how far I am. Hopefully the further construction will also succeed!
Greetings from Belgium
Hello, here is an update of my build log! I am working further on the back of the boat. This is not so easy when you do it for the first time!! What I have done so far did not always fit well but I hope that the final result is good enough! First I connected the lights (LEDs) and mounted the lights at the back with the decorative arch! The lights work great and that will be nice when the boat is finished! I also installed and connected lights behind the windows! The next step will be finishing the balcony. Not easy! When this is all done I want to prepare the boat for further staining, I still have a lot of things to think about and how I can do that best! We will see! I hope you like my pictures! Tips and suggestions are always welcome! Greetings from Belgium
Adding the interior light makes her especially appealing!
Hello everyone! You haven't heard from me for a while, we were in Austria for 14 days with the whole family for a nice holiday!
I also participated together with a colleague boat builder in an exhibition that was organized in three municipalities! Different hobbies such as painters, draftsmen, woodworkers, embroidery, crochet, lace making, many other hobbies and we as model builders could show their work to the visitors in their own workspace! Here are some pictures of the things that I, my wife and my colleague exhibited!
Hello,
In the meantime I have reached the point where I want to finish the hull with paint and stain!
I am still struggling with the choice of the stain colour! I have stained a strip with the Pulverbeits eich mittel no. 164. I have glued that strip to the hull but I am not sure if I would stain the entire ship with this stain!
Here are a few pictures of the current state!
Hello everyone, I finally closed the entire hull as you can see in the pictures. I learned a lot from this and it will help me with making my next boat that I already bought, the HMS Victory Limited Edition!! I only have to finish a small piece at the front of the bow. I also made a construction to put the boat straight so that the wires of my lighting are not damaged! Is there anyone who can help me to determine at what height the waterline will be? I also don't know yet whether I should make the entire hull darker with a darker wood color or whether I should paint the bottom of the boat white up to the waterline! Suggestions are welcome! Best regards from Belgium
impressive
Hi everyone! I've been on hold building my boat for a while and am now back in action! The photos show the progress.
I first want to finish the hull by adding finishing strips between the guns and fitting the guns into the hull. I've also prepared a few things for assembly on the deck. I've also made a sorting tray for all the different sizes of strips to give me a better overview of what I already have and what I still need!
She looks really good, Noël
In the previous post of my Norske Love I was able to show 25 photos, therefore this sequel. Is this the right way to show the further progress of the construction? I don't know how to use the forum properly yet!!!
View attachment 465953View attachment 465954View attachment 465955View attachment 465956View attachment 465957View attachment 465959
What scares me most is the hull planking for my first boat. I hope I started on the right foot and I can finish it on the right foot. I have done a lot of research and read a lot of tips and information on the internet and on this forum. Constructive criticism is always welcome if I do something wrong because I can use your experience!!
my first planks!
This is the place in the construction of my Norske Love so far!
I think the place in the planking where I am now is the most difficult. I'm having trouble continuing to make turns this way.
Good advice is welcome
Thanks for following these posts!!
What a pleasure to find this building again. Superb and a real thrill at the sight of these photos. N.B.: Norske Love means 'Norwegian Love' while Norske LØve means "Norwegian Lion".. ♥ Alt + 0216 > Ø Good luck, Philippe
Great work and a very well organised workspace.
A quick update on my work! I've started preparing to install the guns. First, I marked out all the gun locations on both hulls. Then I painted the green sections at the top of the hulls and used tape to mark out the area where I needed to stain the hull! When I started staining, I thought the hull would get much too dark, but it lightened as the stain dried. I gave both hulls two coats of both the green and stained sections! In some places on the hulls, you can still see how the planking glue is preventing the stain from fully penetrating the wood! This will definitely be a point of attention for the next boats! I then used a sanding sponge to remove the 54 guns that will be mounted in the hull and painted them black. I've also started painting the gun hatches. You can follow the progress in the photos! If you have any tips or tricks to improve my work, they're always welcome!
Two months ago I started building my first boat "The Norske Love". Probably too ambitious! In the basement of my house I set up a working environment to build the boat.
Then I installed all the ribs.
View attachment 465918Assembly of the first deck with underlying space and stairs.
Assembly of the next two decks.
Planking and preparation for gluing the decks.
View attachment 465943View attachment 465944View attachment 465945
I saw the decoration in the next photo in a post from another built Norske Love in the forum. Hopefully I was allowed to use it.
When I see this, I dream and see myself as a child again. Thank you for that.
We've made another step forward! All the gun hatches are painted and ready to be attached to the hull. I made a template so all the gun hatches are mounted at the same 20-degree angle! (See photos). The first row of guns is almost complete!
Thanks, OldPaBe, for the Alt codes. I knew it wasn't LOVE, but LION, but it's a bit faster to type! I hope my progress photos keep everyone interested! Best regards from Belgium!!
