- Oct 1, 2023
For these kind of assemblies I would try and use ordinary woodglue.Got the thin Ca glue all over the okace.
I agree.For these kind of assemnlies i would try and use ordinary woodglue.
That looks good Ted, a little sanding here and there and you've got it.I got the first top glued up. I had to demo most of the left half because the plans are a little bit off from side to side
Once again not perfect but I'm satisfied.tView attachment 532101
ThanksThat looks good Ted, a little sanding here and there and you've got it.
Whenever feasible, I would sand any part, unless the size of the part is such that I, in all honesty, cannot manipulate the part anymore. Sanding does not remove the grain; too many layers of paint do.Argh, this is so frustrating. U work so hard to make a decent looking part and do have the ability to apply a decent finish.
When
I've tried acrylic paint but it doesn't sand well. Now trying enamel but had to thin it to keep it from being uneven. Now I have a splotchy finish.
I really need to find a material/method that is consistent and gives a superior finish.
Thank you. Just venting my frustration at not achieving the results I want.Whenever feasible, I would sand any part, unless the size of the part is such that I, in all honesty, cannot manipulate the part anymore. Sanding does not remove the grain; too many layers of paint do.
As far as applying finish goes, I prefer to stick to one system per part or assembly. Mixing will have unexpected, unwanted results. I might use a colored stain to obtain a possibly darker appearance, always followed by a transparent topcoat. Depending on the look I'm after the topcoat might be semi-gloss or matt (more often than not I'll apply semi-gloss, since I like the appearance). The topcoat must be compatible with the paint system you selected.
Furthermore, a lot has been written on applying any finish, it might be worth your time searching for some more information on this topic on this or any other forum.
ThanksTed, you should visit the section in this forum called "Model shipyard: Building Your Model, Rigging, there you will find excellent instruction in stropping and seizing of blocks.
