- Jan 10, 2022
Not thought that far ahead yet but more than likelyKeith,
Are you contemplating hawse holes although the kit seems not to provide for them ?
**VIEW THREAD HERE** |
That is brilliant - ThanksAs
This framing is more like on Admiralty models than the actual ships so go with whatever works best. Even on the actual ships there were spacers at times, and the size of the spacers varied all over the place even on the same ship as the frames were set up to form the gun ports. Below example is Vengeance 1774. You can see the pieces between frames varies a lot as the siding of the frames varies from the floors to the top timbers. These spacers are only on the station lines but I have no idea why.
On the diagramComing along with the construction of the hawse pieces. x8A and B have been faired. x8B is in its position on the keel, while x8A is placed in the jig for the hawse pieces as all the frames will attach to it. The first piece, F1 is sanded to shape, inside and out. This is the piece that attaches vertically to the hull and is the longest of the 7 frames making up the hawse pieces. It is dry fitted to the cant frame x8A and fits very nicely. F2 is also sanded to shape and takes up its position in the jig next to F1. I must be doing something right as it fits on x8A and the shape forming is instantly recognizable. All good so far
On the diagram HAWSE PIECES it says "Attaching to surface Y8" I presume it means X8B !Coming along with the construction of the hawse pieces. x8A and B have been faired. x8B is in its position on the keel, while x8A is placed in the jig for the hawse pieces as all the frames will attach to it. The first piece, F1 is sanded to shape, inside and out. This is the piece that attaches vertically to the hull and is the longest of the 7 frames making up the hawse pieces. It is dry fitted to the cant frame x8A and fits very nicely. F2 is also sanded to shape and takes up its position in the jig next to F1. I must be doing something right as it fits on x8A and the shape forming is instantly recognizable. All good so far
I used a modelling drum sanded to remove the worse of the Char and Stuff that needed sanding down then Finished of with a hand held sander . Seems OK But before i glue it all in will finly sand it to gicve a clean fiishThat is a fine choice.Myself, I’ve used the 2”drum with 180,
Don’t touch frames until paired and I then hold the paired frames frreehand off the table to bevel inside and out. Using the lines and char allows you to keep things nice and even. 5 minutes to bevel a full frame,
Tip: as you progress, take the bevels right down to the lines, without knowing exactly what my margin for error might be I left several just off the line but that resulted in more sanding……those lines are accurate.
My images show this result so you be the judge on process.
One of the reasons I asked was about your small spacers.Not thought that far ahead yet but more than likely
Yes Ive just checked mine - need break for FRAMESThat is brilliant - Thanks
On the diagram
On the diagram HAWSE PIECES it says "Attaching to surface Y8" I presume it means X8A !
No. x8A is correct. x8B is on the stern side as it is with all the frames. y8 is for the stern can't framesThat is brilliant - Thanks
On the diagram
The instruction quote Y8No. x8A is correct. x8B is on the stern side as it is with all the frames. y8 is for the stern can't frames
My instructions don't say anything about y8The instruction quote Y8
THats what i Mean Its Wrong
its on the Printed White Page Hawse Pieces Bottom Left - Attach to Y8 !!My instructions don't say anything about y8
Looking good Keith- nice oneAll the hull frames are complete and permanently fixed onto the keel, making a complete hull, except for the hawse piece assemblies, port and stbd., which are still awaiting my small repair work-in-progress. In the meantime, I have moved on to the transom. The 5 pieces are shown after sanding to shape. They attach to frame y8B and the stern post. A bit of fine tuning is involved in getting them to fit and they are very awkward to get at whilst in the jig but worked out OK in the end. btw. Almost forgot. Be aware, to achieve the angle for the cant frame y8, you must ignore the sanding line lasered onto the floor timber of y8A. This looks to be a manufacturing error
It’s always a complex part of the hull, Keith. It’s looking very nice.All the hull frames are complete and permanently fixed onto the keel, making a complete hull, except for the hawse piece assemblies, port and stbd., which are still awaiting my small repair work-in-progress. In the meantime, I have moved on to the transom. The 5 pieces are shown after sanding to shape. They attach to frame y8B and the stern post. A bit of fine tuning is involved in getting them to fit and they are very awkward to get at whilst in the jig but worked out OK in the end. btw. Almost forgot. Be aware, to achieve the angle for the cant frame y8, you must ignore the sanding line lasered onto the floor timber of y8A. This looks to be a manufacturing error
Thanks Peter. It sure is difficultIt’s always a complex part of the hull, Keith. It’s looking very nice.
Gr. Peter
That´s another way of doing itKeith,
Looks like they turned out nice.
When I did mine, for others reference, I did them absent the last couple cant frames to get the ends to butt up against frame as evenly as I could………a bit less fidgety.
Tim
Cheers my friendLooking good Keith- nice one
Cheers Grant. All the bestLooking good Keith- nice one
