- Dec 1, 2016
Adding the wales depend on the wood you select and the type of hull a solid hull, plank on bulkhead or plank on frame. It is clear a framed hull makes holding the wales in place much easier than trying to hold them against a solid hull. Because wales are thicker than the planking it helpful to soak the end in hot water. Here you see the difference in color before the orange clamp and after the clamp. The end section was soaking in hot water for about 15 minutes.
The advantage to a frames hull or a hull built as a solid shell, you can clamp the wales to the hull.
so for the wood, because wales are usually black builders will try and use Ebony. Which was used by mater builders. The problem with Ebony is it does not like to bend, it is somewhat brittle. What Hahn did was to laminate thin ebony to a bendable wood. A wale at the bow not only bends along the hull but it also has a twist so Hahn created a positive and negative "mold of the bow and clamped the wale between the two.
You can see on some of his models the laminate wale.
Other solutions is to use a bendable wood and stain it black or use a darker wood besides Ebony. Some woods just do not like to bend while others bend well. What you see being used here is Red Maple also called Soft Maple which is really not that soft, but it takes bending quite well. In general, the softer the wood the better it will bend but soft wood when soaked in water will dent from clamping. hard wood will not dent as easy but harder to bend. The answer is not too hard and not to soft. There are woods in the rosewood family that are dark and will bend, the problem is gluing, they have an oil in them that glue will not hold. Thickness also plays a roll in bending wales. The thicker the material the better chances of it bending. That sounds counter intuitive but the thinner the wood is it gets to a point its structure becomes weak and it will break before it bends.
