Titanic Trumpeter 1/200 by InkMot
B and C Deck Superstructure and B Deck
The B and C Deck superstructure is glued in place. i ended up doing the port side twice because I wasn’t careful with my alignment. Take your time to dry fit B deck (lower right in picture) to ensure proper for and aft placement of the superstructure.
B-Deck is in place, with wood decking and bulkheads for the Cafe Parisian and First Class private promenades, etc. I chose to not replicate the details of the Cafe Parisian or the private promenades because I’m not lighting the model and, well, I get lazy. ;) Seriously though, I’ve set limits on myself with this project so that I can get it done before I’m dead. My plan has been to focus on detailing the obvious and doing the minimum on the hidden areas.
Pay attention to the height of your B-Deck bulkheads. Test fit A-Deck to ensure that your B deck bulkheads aren’t raising A-deck too high. I had to play with this a lot. Also, if you’re installing wooden decking, be careful to clear out space for the bulkheads to mate directly with the plastic of B-Deck, otherwise they’ll sit too high. I chose not to glaze the inside windows of B-deck. I might regret that later, but there are sooo many more windows to glaze on the upper decks.
Your painting look great, just one observation, the anchor well in the bow on the Titanic was white.
Thanks for sharing all your tips. The building up is looking really good and the painted areas so far; amazing. I'm one of those people who, no matter how much masking tape I use, always seems to get bleed in between two colours. :-(
I was basing my colors on reference photos like this. The color ones are from “Titanic Honor and Glory”, the black and white image is from the Olympic…probably later in her career. It appears to me in these photos that the floor of the well was either dark grey or black.IMG_0701.jpegIMG_0699.jpegIMG_0700.jpeg
I like using the Tamiya masking tape. The adhesive on it holds its place without damaging painted surfaces. I just buy rolls of the 3mm size to define my edges and then use regular painter’s tape to fill in the rest. I avoid loading up paint near tape seams, preferring to spray light coats that are just enough to cover. This helps to minimize bleeding and those annoying ridges that form.
These old black and white films were 'ortho' type. Red would also look dark grey, since ortho film was not sensitive to red light. So it cold have been red oxide.
It certainly could be. That’s what’s frustrating about this model. There are so many open-ended questions about what color something should be or how many blades the center screw had…makes me nuts.
I’m tempted to just make the entire model in grey scale.
