Le Saint Philippe 1693 after Jean-Claude Lemineur (Ancre) in scale 1:48
Don't let the perfect be the enemy of the good. No future observer will be drawn to the minor flaws. Only to the overall beauty and superb craftsmanship. Time and the variables of temperature and moisture are going to make their own adjustments to your (splendid) miniature joinery anyway.
Any effort to further fill or perfect these insignificant gaps will only serve to draw the eye to what are (if left undisturbed) virtually invisible.
I had a drawing instructor advise the class "If you don't like a line, you can't fix it by going over and over it". In short. Declare victory and move on. ;)
Gorgeous by the way. It is a privilege to get to see all the work in progress before some of it gets covered up.ThumbsupThumbsupOkay
You are too hard on yourself Paul. Your work has always been a progression of very skillful modelling that many of us can only wish to attain. As I look at your photos today I can only mutter to myself “I wish I could do as well”. Truly great work my friend.
I could not have put this better so Ditto.
Gaps Paul what gaps ? ROTF
Cheers Grant
Good words, Peter.
Very clean work Paul. Just a couple of observations , sorry but I know you do appreciate it when I point these things out in hopefully the constructive manner I intend them to be.
The bottom cills of the lided ports should penetrate the hull planking and lie flush with the finished surface
These bottom cills have raised ends where they fit into the frames, creating a visible ledge either side at the bottom of the finished lining. These raised ends finish flush with the framing creating a stop for the lid.
I fully respect your choice if you made a decision not to include these details to simplify the build, but I know you would be glad someone did highlight it if you missed it in the confusing monograph
Kind Regards
Nigel
