Very helpful, Mirek. My thanks!Witaj
Pawle do szelaku można przyklejać klejem patex i cjanoakrylem na który jesteś uczulony . Pozdrawiam Mirek
Hi Paul,
I use schellac politoer, which is premixed with alcohol and therefore easy to use.
If you use multiple layer it will give a shiny surface as at dockyard models. With a single layer it will mainly absorb into the wood and creates a matt-satin finish. To create a fully mat surface you can lightly sand it with some steelwool after the treatment.
You even have different colors of shellac.
Thank you, gentlemen. I have a small pouch of blonde shellac arriving tomorrow.Shellac is also available in dry form on Aliexpress![]()
Thanks, Chris. I was thinking of the shellac as a top-coat but I do see your point.Paul I am not sure why you would want to apply Shellac over an Oil Finish. Each of them are a finish - why complicate things ? Choose based on each advantage and disadvantage. If you want a top coat apply a finish wax to either after fully dry.
That is a very concerning part of the puzzle, Peter. Once I have everything in place it will no longer be possible to apply a finish. On the Kingfisher I was using wipe-on-poly because I was not interested in highlighting the minimal wood grain in my casello boxwood. The WOP did weaken the bond strength but not enough to matter. I share your concern when using oil which is what I think I should be using to make the most of the pear.But be sure everything is already glued.
Any consideration to a spray-on finish using an air brush?That is a very concerning part of the puzzle, Peter. Once I have everything in place it will no longer be possible to apply a finish. On the Kingfisher I was using wipe-on-poly because I was not interested in highlighting the minimal wood grain in my casello boxwood. The WOP did weaken the bond strength but not enough to matter. I share your concern when using oil which is what I think I should be using to make the most of the pear.
I do manage to turn every step into a major ordeal, don't I?![]()
Not really. I don't even have an air brush much less the experience to pull it off. Do you think an air brush could work for a POF model? What would I spray?Any consideration to a spray-on finish using an air brush?
That’s the million dollar question, isn’t it? Would have to be some thing you can apply in thin coats and would not require wiping down.Not really. I don't even have an air brush much less the experience to pull it off. Do you think an air brush could work for a POF model? What would I spray?
Link to the shellac you're using?I ran a test the new amber shellac flakes than arrived recently on one of the reject frames (there are many) for Fame. Here are the results.
First pic - one coat of 1lb cut - almost looks unfinished - very flat and the wood is sealed.
Third pic - three coats 1lb cut - has a nice luster. Each additional coat will add more gloss and deepen the finish as desired. In this test I also applied a thin coat of wax as a top coat.
Thin coats dry superfast - less than 30 minutes - and its sands easily to ensure future adhesion (one of the major reasons I will be using it as I will be applying finish to hard to reach areas as I continue to add assemblies onto the model). Also its easy to repair scratches - just add a little more shellac to the area and they vanish.
Ha! I can completely relate to your “translation mode,” Paul — I think we’ve all been there. It sounds like you’re handling the Saint Philippe project with both patience and humor, which is half the battle with these complex POF builds.Hello Friends,
As I continue to explore wood finishing options (translation: throwing good money after bad) work continues on the Saint Philippe stern section model.
I have now emotionally committed to working on the exterior hull planking as my next major effort (translation: kicking the can down the road on the wood finishing decision). But I had already begun work on the rider frames and flat crotches so I thought it would be best to wrap those up before starting something new (translation: if I don't finish these now, I'll forget how to do what I am doing).
Here is where I am at the conclusion of the weekend:
I'm sure you noticed the gap between the rider frames and hull framing. This is intentional. The rider frames actually sit on the ceiling strakes - but I'm not installing ceiling strakes - thus the gap.
I had hoped to show you one more rider frame (actually, two half rider frames) that sit on the upper flat crotch. Unfortunately, while working on these half frames, I cut the fairing bevel in the wrong direction. Double unfortunately, I have now used up the pearwood panels needed for the frames (6.2 mm thick) so I am back to being a woodworker instead of a modeler. Not a major set-back, but still frustrating.
Thanks for stopping by!
