HMS ENTERPRISE 1774 by RichardJJS 1:48 scale. New Kit from M.D
a lot of the frame sections are totally different as well I think you will need to stain the outside edge before gluing
I stained my blandford and ruined it as it was complely uneven
The beeswax/turpentine finish works quite well and blends fine, even allowing extra coats on lighter wood to get closer to match.
That said, mandatory to avoid finish where glue joints are needed.
Tim
is the beeswax liquid - turpentine rather that tubs subs ??
Have zero idea what tubs subs is.
Beeswax is wax, i.e.solid.
Buy food grade beeswax pellets and dissolve them in distilled turpentine.
The turpentine evaporates off and then you can buff if you wish.
Tim
Don't use food-grade or household beeswax! It's so acidic that it will damage the surface over time. Look for special wax for restorers and artists in the varnish and paint section of art supply stores.
At what point inconstruction does one use the beeswax and how. Wouldn't it interfere with glueing if done early?
I recommend the microcrystalline wax "Cosmoloid H-80" from Kremer, Germany. This wax penetrates deeply into the wood and preserves it. It polishes easily. Preserves wood, metal, plastic, and other materials with wax impregnation. Keep in mind that nothing can be glued to a waxed surface. Therefore, before waxing, cover the areas of the model where parts will be glued.
Prepare a solution: 20 g of "Cosmoloid X-80" per 1 liter of clean gasoline. Apply the solution with a brush, swab, or immerse the part in it. After the gasoline evaporates, a thin film remains. This can be heated under a table lamp until it shines and then rubbed with a rag until glossy.
Wax is completely neutral to wood and metal, creating a durable film that is water- and dust-repellent. Keep in mind that nothing can be glued to a waxed surface. Therefore, before waxing, mask off any areas of the model where parts will be glued.
I also recommend MinWax Dark Wax Polish, 454g Manufacturer: MinWax, USA. Shelf life: 8 years. This dark wax polish, based on artificial wax, protects wood surfaces from water and mechanical damage, creates an antistatic coating, and imparts a matte shine to treated items. Regular application of this product helps keep wood surfaces clean and maintain their shine. Can be used on any treated surface, both old and new.
Liquid wax is also sold in restoration stores, and the selection is quite extensive. But, in fact, you can make this mixture yourself using the waxes I just described.
What is the pH of your household beeswax? Unless something else such as castor oil or olive oil or stearic acid, is added, the pH will be close to 7. Wood typically is more acid with a PH of 4 to 6 so beeswax, household or otherwise should be fine. Never a bad idea to check the ingredient label to be sure about additives, though, natural or otherwise to be sure it is not going to problematic.
Last thing I want is to work with gasoline. The turpentine evaporates off, gasoline, does not.Also, the H-80 has no color….IMHO unsuitable for my project. Not looking for only preservation, I want preservation with a color componant.
FWIW all beeswax has some acidity yet it has been used literally for hundreds of years. Mine is fairly low as far as acid. I want the additional benefit of having some alteration of natural wood depending on coats which additionally blend seamlessly.
Lastly, any type of traditional “ polish”, I cannot imagine how you could evenly apply it to all of the fragile inner structures evenly, not building a canoe here.
That said, in light of current questions…..folks, you need to finish wood in incremental steps when the addition of structure will eliminate future access, avoiding glue locations.
FWIW this is the exact process some folks I follow who build museum level projects. Ultimately, whatever floats your boat
While I am waiting for my New Hawse pieces I decided to Clean and attach the Inner Planking - although its more of the supports
Getting them to stick to the Inner Frames has been a nightmare
Using 3M Tape seems to be good
Have marked to position with the Jig Pieces (One Shown)
Once 2,5, 8 have dried i will check the Jig again
And Add more info
The Upper deck Spirketting Is what the deck planking goes into on the side of the ship
(Hopefully i can get Done bu this time NEXTYEAR
Hope we dont nedd to float this BOAT !!
Thanks
Tim
Sorry Turpentine Substitute
The jig fixtures to locate the position of the deck clamps, limbers and such is ingenious. Maybe it has been around for some time, but a first for me and it will be remembered.
When you use 3-4 at a time to locate and mark clamps they come out virtually exact as to position. All my beams came out pretty much exactly. level.
Ingenious and simple.
All the volumes I’ve collected, never seen this approach.
Hi Guys
just starting the stern frames
Does say anything about B23 d (the short one) is t glued to B23c and faired in)If so inside B23c
Also at what height is the cross member G1 18 & G1 19
The instructions really are not good
Hi Guys
Hoe you are OKView attachment 552065
Short piece goes outside, ultimately faired when you build door and support frames and then faired.
The G18/19 is a lamination which I wasn't crazy about, built another from stock.
If you jump to 114-116 you’ll get a sense of placement, especially if you trial fit the large transom sheet to size everything up.
Strongly suggest you consider drilling out and pinning the bottoms onto the top of transom.
Also, you should make constant reference to Victors build of the prototype, while there are changes vs the kit it remains quite useful.
Tim
Tim
THATS GREAT - thanks
Not sure what number the lower cross member is
no number for it
GUYS if you are cutting out G9 - 9 its lots of pieces so number or tape it
Ive cut it out and made a paper template just to align it all up
