ZHL San Felipe 1690 - Ted R
Installed between deck bulkheads 7-11.
Painted recessed dummy cannon blocks.
The ink passed the smudge test perfectly.
I've been trying to get what appears to be correct alignment on the three deck platforms at the stern for a few hours. I can't get them all aligned due to interference with the dummy cannon blocks. I've decided to abandon the cannons at the stern and build closed cannon ports.IMG20251028142404.jpg1761686883156816829779207133635.jpg
By the way, using ink vs paint could leave your fingers stained.lolView attachment 553356
BTW, when you use the black ink for imitating ebony, the positive side is that it enter the wood more deeply than paint. If you then scratch that piece of wood, the scratch will not be noticeable as if you scratch a painted wood.
Cheers !!!
Daniel
Cheers !!!
Daniel
Thank you again for this kit. I'm having a great time building it. You should reconsider and get you one again.
Installed the third level deck at the stern.
The instructions call for the installation of part 48 on the keel. See attached figure 15a. I don't see the part in the figure or any subsequent photos.
IMG20251029072508.jpgIMG20251029072336.jpgIMG20251029072336.jpgIMG20251029072409.jpgIMG20251029072341.jpg
Here we go again.
The next step is to install part 20.
The part is longer than shown in figures 19 and 20.
Further figure 21 seems to show the part as supplied as shown in my first photo.
Based on the last photo I'm going to cut the part shorter assuming it will be easier to glue in a block to extend the part rather than trying to shorten it with a chisel at a.later step.
