HMS Enterprise 1774 POF 1:48.
I also have a problem with cherry wood, so i buy a cherry wood handle scale set for knifemaking. Each cube costs about $5, and it's enough for a lot of work in modeling. You can match diffrent variants of colour, shape like cube, flat strip etc. and its ready to cut and super cheap.
I always look for second hand furniture of cherry wood. The most you find is from European Cherry and sometimes it's an old table for free.
Good morning. I decided to scratch build (the kit only provides hand pumps) some chain pump housing. My plan is to have one covered and one open. I will attempt to 3D design and print the wheel and chain in the one housing.
I don’t have much cherry wood to play with so they are made from scraps hence some unusual wood joins.Redface.
View attachment 553582View attachment 553583View attachment 553584
Hmmmmm ! I clearly cannot convert inches to mm as these are too small. :mad:. Redo time again. My modelling is failing me at present ROTF. OH well let’s see what attempt 2 will bring.
Cheers Grant
PS my wales are on hold until I source some wood to do the top and butt planking method as the wood in the kit is too narrow. Eish.
Can't say anything sensible about the scale, but scratch building is fun. Redo is an integral part of it; one can make drawings/sketches all you like, but the proof of the pudding is in the actual build part/assembly. Then all the flaws of your tinkering come to the surface and every once in a while one has to admit defeat and start again.
Your handiwork looks great though.
Good morning, Grant. For the best reference, it's best to place them on the model. That sometimes softens the judgment.;) I do like the fact that you are more and more build in scratch.
Good morning Peter. That is good advice. They did not look too bad when I first put them on the deck however when I put the main "bits" on it was immediately evident these would not work. Anyway some of my wood joins especially by the sliding mechanism are not good, so a redo was probably always on the cards.
They look great. How much too small. Would it be noticable?
Thanks Richard. Unfortunally the pumping mechanism would not fit to the main "bits" properly so a redo is unavoidable.
Some dealers have 'pen blanks', which are smaller but often very nicely sawn and selected material.
Good morning Gentlemen. Thanks for this. In SA there is a company called rare woods which has some awesome wood. My problem is I don't have any power tools so to cut by hand is a tad difficult for me. They do cut some wood but not small enough for modelling. I may give it a go out of necessity Redface . For me to import product is just silly expensive as our tariffs are worse than Trumps ROTF.Cheers Grant
Good morning Stephan. I will give it a go with some of our furniture makers. Maybe they can also cut it to size for me......hmmmm.
Those pump housings turned out great. Are you sure they won't work? If you want I can measure the ones I built on the Kingfisher for comparison...
Good morning Paul. Thank you for this. That would be of great help. I will try get the conversion from inches to mm correct. ROTF. Once upon a time many years ago in a galaxy far far away I did math and statistics at university and now I can't even convert inches to mmROTF.
Nice work. Looking more and more like a scratch build!
If you redo, I'm sure there will be some improvements, but they look pretty darn good as is.
Good morning Brad. Thanks for the encouragement. As I said to Peter some of my joins were not so good so a redo was probably always on the cards. Now I dont have an option:D.
True story Johan. It is more fun building scratch parts and redo's definitely are part of the equation.
Cheers Grant
Heh. Another techno-progress fanatic, get to work Brother...
My 1:48 cisterns are 11 mm wide, 23 mm long at the base and 22 mm long at the top (they taper just slightly), and 18 mm tall. I also have legs on them about 5 mm tall.
You're joking about doing math conversions, right? It's called the internet ROTF:
View attachment 553819 View attachment 553820 View attachment 553821 View attachment 553822
Thank you most kindly Paul.
Nope-I don’t know what I did but I “cocked” them up the first timeROTF. PS don’t tell anyone ROTF.
Cheers Grant
Good morning, I went for my first pieces of wood also to a furniture maker. They got a lot of cut offs they throw away or burn.
Indeed. If you have any furniture manufacturers around, it would be worth a trip to beg some scrap. We give away scrap cherry, walnut, maple, oak and poplar to our employees by the dumpster-bin full to burn as firewood. All of them small, manageable offcuts.
