Le Fleuron 1729 scale 1/75 - Boudriot & Delacroix
Thank you all for your contributions on the topic of windows. They will definitely help many people.
I thought for a long time about what to do with the windows. In the end, I decided to stick with the drawings and leave them ajar. That was my intention from the beginning, so that as much as possible could be seen inside. This means that I will also open the windows on the upper deck in the same way.
So I tried to cut out the dolphins. The height of the dolphin is cruel for me, only 10 mm.
And I immediately carved his sibling out of the boxwood.
I added lilies and added twigs under the coat of arms with the inscription.
Thank you for your support.
I didn't add anything for a long time, because there was nothing. I worked on the second gun deck and that took a while.
And of course another 4000 nails
View attachment 565491View attachment 565492View attachment 565493
I made a set of internal lining and on the left side also external.
View attachment 565495View attachment 565496
Your tree nails and carvings are very nice! Magic Mike
Zdravím všetkých nadšencov fóra v novom roku. Nech je aspoň o trochu lepší ako ten najlepší rok, aký ste doteraz mali.
Pokračujem s výzbrojou druhej delovej paluby a zábradlím na prove. Le Fleuron mal 26 kusov železných 12-librových kanónov. Zatiaľ sa mi podarilo nájsť 4 kusy.
A ešte jeden pohľad s osvetlením.
View attachment 569140View attachment 569141View attachment 569142
View attachment 569143View attachment 569144View attachment 569145
Zdravim naspät na Slovensko! Velmi dobra praca, lod je super. Pozdrav od zaciatocnika - pracujem doteraz len na stavebniciach. Muoj sen je „scratch build“ - snad neskuor.
Only 6 more cannons and the second deck will be armed.
In the meantime, I shopped at IKEY and secured a second table with benches, just like on the first deck, only this one is longer.
And it's in its place. Finally, there's something to look at.
Toilet door
