The first steps for rigging: the chain plates with deadeyes.
There are some differences between the mainmast and the mizzen mast. First, for the mizzen mast:
The plates extend through the handrail on the bulwark and have an eye on top.
The lower deadeye with a hook is inserted into this eye. The upper deadeye, wrapped around a shroud covered with tarred twine, is tensioned with a rope.
The hook entrance of the lower block is tied to prevent the hook from accidentally falling out of the eye. This is important for the mainmast, because when the mast is lowered during fishing, the hooks must be absolutely sure not to fall out of the eyes. This has also been done for the mizzen mast.
Here too, it became a matter of exploring what was possible. The deadeyes of the mizzen mast are 15 cm in diameter. That is 3 mm in scale. The chain plates are 8 cm wide, which is 1.6 mm wide.
*I made the eye from the smallest eyelets in my stash. But the 'indicated 2 mm' is actually 1.7 mm internal and 2.44 mm external. The wire itself is 0.4 mm in diameter. That's almost the same size as the deadbolt.
I crimped the ring as much as possible. This way, it has a slight overlap. But that also provides a bit more grip for soldering onto the lip of the iron.
*I sawed the 1.6 mm wide strip for the 'iron' from 0.15 mm brass sheet. Between the eye and the lip, you can see a piece of solder wire with a diameter of 0.75 mm.
Soldering: I slid the eye and the lip against the solder and applied light pressure while heating it with the flame.
For making the sharp pictures I had to use my macro-lense with extension tube.
The next step was the band around the 3 mm deadeye with the hook:
For this, I sawed a 1.1 mm wide brass strip. I bent it into the correct round and drilled a 0.6 mm hole for the 0.6 mm hook wire. I pressed this together with a piece of solder wire. The block fit perfectly, but I used a dab of CA to be sure.
All the brass has been "burnished."
Fitting it in was a skill in itself:
The iron with the eyelet not yet secured in the bulwark. The top deadeye was secured around the mast with a piece of wire.
The hook opening was "tied" with a piece of black Serafil.
This is what it looks like from the inside of the bulwark:
Everything is clamped in place.
To see the proportions, the bottom deadeye with hook and eye has been pasted into a photo of the original:
The eye could be a bit thicker. But 0.1 mm to scale is already quite...
I'll see if I can bend an eye from 0.6 mm wire to scale. And flatten the top of the hook a bit to make it a bit more robust.
But everything is again 'on the limit. With reference:
