Yup. You've got a gift...
That is an incredible bit of carving in such a small area.
Jan
Witaj
Pięknie rzeźbisz Hermanie .Pozdrawiam MIrek
Nice carvings on the catheads it self and on the lion, Herman.
Thank you very much for all your kind words. Much appreciated and motivating.Good morning Herman. What Paul said. Definitely something to marvel at. Cheers Grant
Thank you Stephan. When I started I first visited your build log, it was the first that came up looking for "lionhead".I know how difficult it is to make a small face like that. A little taken away to much wood and it is ruined. Impressive.
Thanks Maarten. I am now working on the 6 statues adorning the vertical struts on the foredeck. Those are only 4,5 mm wide, so another challenge.Great small carving Herman, this promisses a lot for the rest of the carvings on your model.
Thank you Gunther for this generous comment. A cathedral?.. then I would have taken some further artistic freedom and have redesigned my simple scuppers into gargouilles,Hey Hermann,
What are you building there? A cathedral? I'm only asking because this model is absolutely adorable. I'm speechless. Thank you for this ahaaaaaaaaaaaaaaaaaa... effect! Beautiful model...![]()
Indeed, when it's so small, no steelwool. Sometimes I use these rubber polishers from Alie.Thank you Stephan. When I started I first visited your build log, it was the first that came up looking for "lionhead".
Your remark "a little taken away... " is spot on. Even my usual modus operandi using steel wool is too much and will ruin details on this scale. I now use an old toothbrush to clean up afterwards.
You have skills Herman. Very impressive. Cheers GrantI have made the 6 statues for the foredeck. I designed them with a sailor/warrior head, a similar, yet larger head will later be applied on the top of the railing. In the last two photos they are standing loose on the deck.
True storyYou have skills Herman. Very impressive. Cheers Grant
You made a nice couple of statue/man/heads, Herman.I have made the 6 statues for the foredeck. I designed them with a sailor/warrior head, a similar, yet larger head will later be applied on the top of the railing. In the last two photos they are standing loose on the deck.
Love it, Herman!
Very impressive carving
Thank you guys for the compliments.Beautifully done indeed! I'm always a little jealous of this kind of skill. I've often tried to create a simple wood carving, but I never get an acceptable result. It's wonderful to see you succeed.
Thanks Maarten.Looks great Herman,
Do you give them a wash with bitumen? Especially the small details will be better visible then.
