Bluenose Model Shipways 1:64 Beautiful ship
Connecticut, U.S.A.
Being fairly new to shipbuilding I am slowly progressing to more and more complex builds. However i must say that even before I knew her name I always thought that the Bluenose was a simply beautiful ship. The flow of her hull is striking. I was able to get a secondhand kit of the model shipways build (MS2130). I have had it stored away for some time. We currently have 2 houses, one on the east coast and one in Arizona. I recently set up a small workshop in my Arizona house (with permission of the Admiral) and I decided to build the Bluenose here, when we are here on vacation.
That being so, this build log will progress in fits and starts depending if I am here. As of this time I have already been working on it for a while, but I have saved pictures of the build and I will "catch up" to my current state of where I am.
I am really using four sources of information to build. One is the instruction manual which appears to be fairly complete, but does a lot of things in a sequence I find not quite logical. The 3 other sources I am using is Jeff T's build.
The build from the suburban ship builders site.
And Gary Brinker's You tube series.
I have studied all of them and they are all excellent. I have learned that there are at least 4 different ways to do this build and they all come out looking great!
So Lets go.
Here is the kit
I am not sure how old my copy of this kit is but it appears pretty good. There are some pieces missing that I will have to scratch build, but all in all it is fairly complete.
The set of plans that come with it look fantastic. As did with my Constitution cross section, I hung the plans up on the wall using a magnetic holder used for posters, very convenient.
The 3 parts of the keel fit together quite well. I glued them with some epoxy on a sheet of wax paper and let them set. After that I drew in lines for the bulkheads and labeled them. Taking a copy from the plans I cut out the outline of the rabbet and copied them on both sides. You can notice on extremely weak area on the frame, where bulkhead N is located. With my usual luck this of course snapped and I had to repair it with some epoxy and a small nail. I then beefed up the joint with some pieces of wood glued to each side of the frame.
I cut the rabbet and bearding line, mostly using an x-acto chisel blade. The plywood used here did not allow for as smooth a cut as i would wish, but I smoothed it out later with sanding sticks.
Here are two later pictures of the areas that I reinforced. The first is the area by bulkhead N that snapped off. Like I said I glued it on with epoxy and a nail and then placed 2 small pieces of wood to beef it up.
The two joints of the keel were also reinforced with scrap pieces of wood, one on each side.
Unfortunately I did not take pictures of the placement of the bulkheads. Unlike some other reports, My bulkheads fit perfectly in place and were exactly at the level of the top of the keel piece. I clamped them in place using lego pieces as others have done to insure squareness of their installation. The pieces fit very well and did not require much, if any adjustment. The bulkheads were attached with PVA glue. The stanchions on top of the bulkheads were trimmed to 1/8th" square using a small jig to insure everything was aligned. Many people cut these off and place false one on. I thought it best to try to leave these here to give me better support and alignment when I build the bulwarks.
As you can see, after the bulkheads were glued into place and the glue dried, I reinforced the bulkheads with strips of wood to prevent flexure. I was afraid the bulkheads would snap off when I was fairing the hull. These strips provided a lot more structural rigidity and i recommend them. I measured the space between each bulkhead to cut the strips. The space seldom varied more than 1mm at most between one set and the other and were almost always the same port of starboard. This gave me a lot of confidence that the bulkheads were set correctly.
The bulkheads were then faired using long sanding strips I made by using pieces of foam board glued to sandpaper using rubber cement. I find these boat boards have some "give" and make sanding easier. When the sandpaper is used up it is an easy matter to take it off and replace it with a new piece.
Next up were the horn timbers. There are 2 small strips of wood that go along the rear of the keel to support some of the planking as it goes from an area with a rabbet to the transom. After installing these strips I took a piece of planking to makes sure they would fit well. One side was set too far away from the end of the keel. I took a thin strip and glued it agains the horn timer to give it the correct "depth".
After the horn timbers the stern blocks were next to be installed. These are two blocks in the rear of the ship that shapes the transom area. You get a block of wood that you cut into 2 pieces. I then took a copy of the finished block from the plans and glued them onto the plans in 2 dimensions. Using a small jeweler's saw I cut out a rough outline of the blocks in 2 planes. Fitting them agains the last bulkhead they fit well against the bulkhead and the keel. They were then glued into place. Once the glue thoroughly dried I shaped the pieces with some coarse sandpaper. This took a while. I wanted to make sure the pieces were symmetrical and the curves smooth. I was pleased with the results.
I then attached the "Great beam" these are 3 transverse members that divide the foredeck from the quarterdeck. The instructions would have you install this after putting in the waterways, but this made absolutely no sense to me (or the other 3 build logs I have seen). The great beam is made up of 3 laser cut parts that have a gentle curve. One goes in front of of the H bulkhead, where it provides a place for the foredeck plaks to land on. To get it level with the bulkhead you have to notch out the keel piece in front of the H bulkhead. This was easily done with a file.
On other builds for some reason there was a rise here because of the bulkhead and they had to install a shim to get the decking to fit. For my build it seemed to fit perfectly.
Now onto the waterways. The Bluenose waterways are really divided into two parts. On the foredeck it consists of three planks. The outer planks between the stanchions of the bulkheads, a plank next to that on the onside and a final inner plank that tapers to the level of the decking. The quarterdeck has a single plank that goes between the stanchions and interior to that is a plank that the deck will be nibbed (notched) on to.
The instructions would have you cut a series of planks between the stanchions and glue them from the "shelf" of the bulkhead that was created when you thinned the stanchion to 1/8th" on to the next stanchion. That's a bit difficult to do. What I did was to place the strips that go inside the stanchions and rest on the bulkheads. I then glued small pieces of scrap under those planks to act as shelves to support the outer strips.
Once these support pieces were placed it was easy to glue short pieces between the stanchions and to the inner strip.
Then third innermost strip was then tapered and attached.
Once that was done, the outer strip was lightly sanded to "curve" the outer strips and make them seem more like one continuous piece.
I then installed the knighthood hawse timbers and chafing blocks that go in the bow of the ship where the bowsprit enters. These are just 3 pieces of timber that i shaped and glued into place.
I then painted the waterways gray. When I paint I first use sanding sealer on the wood to prevent the acrylic paints from raising the grain of the wood. I then put a few coats of gray on the waterways.
Getting ready to plank the ship. I checked the fairing by placing a planking strip along the bulkheads and seeing if the strips made a nice curve along the bulkheads. I noticed that one bulkhead (E) on the port side was significantly lower than the plank and made no contact with it. I have not seen anyone else report this. In order to correct this I glued a thin piece of strip and soaked it for a few minutes and then clamped it into place along the bulkhead. I let it dry for a few hours and then glued it into place.
After this strip was attached I sanded it and faired it.
Checking again with a piece of planking, the planking now made even contact with all the bulkheads.
The frame of the ship is looking nice and straight and ready to be planked.
The planking has begun. I am using full length strips since (hopefully) the hull will be smooth and there will not be need to show joints. At this level at least the one strip does not cover the length of the ship.
I angle the front of the plank a bit to fit into the rabbet. I cut the plank at the middle of a bulkhead to continue the other plank. I sand the edge that abuts the previous plank to form a light bevel. I know this will be the easiest part of the ship to plank. The only difficulty I find is the planks curving around the transom need a larger bevel to help prevent them twisting around the stern block. I have used PVA glue as I found it gives me a lot more time to adjust things.
I have been using one long strip going bow to stern and then alternate with the next row going stern to bow.
The planking continues. I am taking my time and trying to make sure every strake is installed as well as I can do it. I think this will save a lot of time when I have to finally shape the hull.
I have started to do the planking in almost a 2 step way. I cut the plank to shape and bevel the edge that abuts against the already installed strake. I then soak the strake for a few minutes in hot water. (they are so thin it doesn't take much) I clamp the strake into place and let it dry. It then forms to the curve of the ship which you can see in the next picture.
The strake is then glued into place.
Good morning Rob. I will certainly pull up a chair. The BN was my Dad’s favourite. He was a sailing fanatic owning and racing offshore yachts. I remember in his study he had pics of the BN on his wall. Enjoy. Cheers Grant
Grant, as always, thank you for your kind comments. I always liked her also, even though I didn't know her name. As I said, this will be an on again, off again build log so it will go slowly. But I will finish her.
Rob
