Thanks for your comment John.Clemens,
Always a pleasure dropping by your excellent build of this ship.
PS: your deck gratings are also perfectly scaled - looks great
Regards,
I do my best.
Regards,
Nice progress, Clemens. Strip by step working on the top masts she is getting more body.The weekly update for week 08-2026.
Thank you for your likes this past week.
Regarding the "twisting" of the upper deadeye on both mizzen backstays, that problem has been solved.
After some testing, I discovered that the twisting was occurring in the rope running above the deadeye to the mast.
With the slightest extra tension, it started to twist. In this case, clockwise. Since my lower deadeye has a hook in the eye near the hull, I was able to unhook it, then turned it counterclockwise two turns and re-hooked it. At this point, the upper deadeye was almost straight with the correct tension.
Then I used a solution of a forum member on the brown wire. I coated it from top to bottom with a thin, colorless wood glue.
And, I gave the deadeye a little counterweight and secured it so that it could still twist a little when I removed it.
Below is the result on both backstays.
View attachment 580061 View attachment 580062
I now see in the photo that a deadeye block at the bottom of the rigging has also turned slightly. Great, we'll use the same trick.
Then I set the mizzen topmast stay and fitted it with a single block and hook on the deck, and a double block and tackle to the pin rail behind the mainmast at pin position 68, as per the plan drawing. In the photo of the rigging, you can see the connection at the top where the flagpole will be.
I also added some extra eyes to the deck. They might be necessary or serve as a helper eye, but I could still fit them in now. If they're not needed, they'll turn black and you'll probably not notice them later.
Continued with the mizzen topmast rigging. Most of the ratlines are now complete. Very short ones at the top.
I use quite a bit of extra length. This makes working with it a bit easier. The shorter the thread, the harder it is to tie the knots.
Finally, an overview photo of the current state. I've now removed the ship from the "heavy yard" and placed it on the simple work stand.
I have to rotate the model a lot in this state, and with the heavy yard, that's a bit more difficult.
However, I now have protruding parts at the front and back that aren't protected by the heavy yard dimensions. So be careful and proceed with caution.
Next week I'll finish the mizzen topmast shrouds.
After that, I'll probably see if I can make and install the rudder if time allows.
We'll see.
Have a great build week, everyone.
