Purchased shortly ago / sthg new in your workshop -> present it here
Jaager -- Thanks for the suggestion. I found the green sharpening compound for next to nothing online and will pick up some leather bands next time at the hobby store. Is there a way for keeping serrated edge knives sharp? I've got a Japanese hacksaw that I use in my miter box that I use alot and will eventually need to re-sharpen the serrated teeth. Any suggestions on this score would be appreciated.
I would like to see a tutorial on keeping razor knives sharp, the materials needed, process, etc.
I have a serrated knife that I use for slicing tomato. I keep a ~1000 grit stone and hone it - being for food the edge does not have to be able 'to split water molecules when you blow on it' sharp. Being a stone the serrated points cannot dig in as it is honed edge first. My serrated blade is coves on one side and flat on the other. I do nothing to the coves side. Just working one side still gets me a sharp edge back.
I suppose I could strop it since that is done away from the edge. But I think that the sharp points -even being dragged away on the surface of leather would really tear it up.
If you don’t already have them, a set of Zona razor saws is a worthwhile addition to your tool kit. These are inexpensive; look on your favorite on line tool source like Amazon. Blades are replaceable and cheap enough that I don’t bother trying to sharpen them. In addition to cutting wood, I also use them for cutting brass tubing.
The Zona saws are much better than the ones that fit into Xacto knife handles as they bolt to the handles.
Roger
These work well
Rob
These work well
Rob
Wow. These look dangerous...my wife and our 15-18 serrated knives that need sharpening thank you!
Roger
Roger -- I need a razor saw / miter box combination that actually are sized for each other. I've been using a 6-inch miter box that is too wide for my Japanese razor saw and I'm not getting fine cuts. Looks like Zona has a couple of razor saw & miter box combos in my budget. Thanks.
