Bluenose 1:64 by Model Shipways - Build log
Do I paint the hull or do I install the rails?
  • Hull
    Votes: 0 0.0%
  • Rails
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
7/30/25 to 8/15/25
Before working on to the furniture/structures on the front 1/2 of the ship I must create the “unknown” piece located next to the wheelhouse. It is 1/2” in diameter and is 0.20” in height. I use a 1/2” dowel and sand a curved look to the end.
To make it look like it is two separate pieces, I hold the dowel in my miter box to cut right at where the sanded curve begins. At this point, I cut a groove using a saw completely around the dowel. I then use a small, pointed file and sand the groove a bit to open it up.
I then put a mark just a little more than 0.20” and cut completely through the dowel using a saw. I sand the entire piece until it is 0.20” in height.
Two coats of white paint, a little sanding to match the curve of the deck and it is ready to be glued in place.
On to the skylight and companionway. Neither of these are very complex, but since there are not any instructions, I created them much like I did for the previous structures. Creating the instructions took about an hour.
During the Rocky Mountain Shipwrights workshop on Saturday, I cut and sanded the four wall pieces of the skylight and rough-cut and glued the three taller sections of the companionway (that were taller than 1/2”).
As with many of the steps of creating these two structures, I did certain tasks at the same time - for example as stated above, I cut the pieces for the walls of both structures at the same time. For the build log, I will detail the building of the two structures separately.
Skylight
The skylight walls were made with 1/16” x 1/2” sanded down to 0.3” (the height of the skylight).
I need two lengths of boards that are 0.56” and two that are 0.44”. These are glued together using 1/8” x 1/8” x 0.25” posts in the corners creating a 0.56” square base.
The sides are sanded, filler added and sanded again. The corners are then rounded using sandpaper.
4mm holes are drilled on the port and starboard sides and given a little reaming/sanding with a small round file until the portholes fit.
The skylight is given two coats of white paint.
The roof is created using six 1/16” x 1/8” x 0.7” planks. Used pencil on the edges to look like grout. Once glued together, it is sanded down to 0.68” square and the corners are rounded.
I had built a jig to help with sanding edges square (90 degrees) and at 45 degrees. It is a shooting board, but for sanding instead of using a plane. It works ok, but I need to add some “wings” to hold the sandpaper up at the height of what I am sanding.
The roof is given two coats of classic pecan stain.
The portholes are glued in place and then so is the roof, leaving about 1/16” overhang on all the four sides. As before, thanks for the portholes goes to Alice, my deceased MIL, as she wanted to be part of the hobby that I get so much joy from.
I stained a couple of short (around 3”) of 1/16” x 1/16” stock which will be used for the coamings with golden pecan. These are then cut down to size, miter sanded (using the updated jig) and glued in place at the bottom of the base. This should be enough for both structures.
The bottom of the skylight is then sanded to match the curve of the deck.
The skylight is then given a coat of clear satin finish.
After a suggestion from Phil in the RMSW, I will hold off on glueing it in place until I determine if it will get in the way while I am rigging.
Companionway
The sides of the companionway are quadrilateral (like the wheelhouse) whose sides are 0.3” (fore) x 0.56” (aft) x 0.65” (bottom) x 0.71” (top). The top is at a slight angle, about 78 degrees.
To get the height which is just over 1/2” at 0.56”, I cut two 1/2” x 1/16” and two 1/16” x 1/16” pieces to about 0.67” and glue them together creating boards that are 0.56” x 0.67”. I do the same with two pieces (of 1/2” x 1/16” and 1/16” x 1/16” that are about 0.45”) to form the tall (aft) side. The short (fore) side is not over 1/2” so I just cut/sand down a 1/2” piece of 1/2” x 1/16” to 0.3” x 0.43”.
The walls are glued together with 1/8” x 1/8” posts in the corners.
In looking at pictures I thought there was a need for a 1/16” x 1/16” board on top (in addition to the one on the bottom) of the front wall. This was true for the main cabin, so it made sense, but when I really looked at the pictures, it was not needed, and I had to cut/sand it off.
Cut horizontal groove in center in the aft wall to simulate two panels that lift out when the entrance is open.
It was at this point I realized that the aft wall should have been pushed in slightly to the fore instead of even with the side walls. To correct this, I added two pieces of 1/16” x 1/16” boards vertically on the aft corners.
I cut six 1/16” x 1/8” planks that are 0.8” and used pencil on the edges. They are glued together and then sanded down to 0.78” x 0.7” (using the jig) with slightly rounded corners.
The aft edge of the roof is notched in about 1/16” to match the shape of the base.
The roof is placed into golden pecan stain for a few minutes then dried off and put in the stain again for a second coat.
The rails for the sliding cover are created by two sections of 1/16” x 1/16” boards that are cut to 0.78”, painted white, and glued onto the roof. The sliding cover was made using 1/2” x 1/16” x 0.7”. The 1/2” is sanded down to 0.45” while all but the aft edge is sanded to give it a curved appearance. It is painted white. It is now where I see where the 1/16” x 1/16” board (previously removed) is needed. It is needed perpendicular between the rails as without it, a 1/16” gap is created between the stained roof and the sliding cover.
I cut and sand a piece until it fits between the rails and glue it in place. The aft facing side, in addition to the aft facing edge of the stained roof, are painted white.
The sliding cover is glued to the rails.
Using the pre-stained 1/16” x 1/16” stock, I created the coamings. These were then cut down to size, miter sanded and glued in place at the bottom of the base.
The companionway is then given a coat of clear satin finish.
The bottom of the companionway is then sanded to match the curve of the deck and given a coat of clear satin finish. As previously with the skylight (and main cabin), I will hold off on glueing it in place until I determine if it will get in the way while I am rigging.
Next up is any of the remaining eyebolts and rings. I have already installed 16 of them to the bulwark stanchions, eight along each side, leaving only four to be installed along the front of the main cabin. Since the cabin was not glued onto the deck yet, these are easy except that while looking at pictures of the cabin on Suburban Ship Modeler, I noticed that there is a small fascia right under the roof that was not detailed in their instructions. I look at a couple of other build logs and it is hit or miss if this is there. I will admit that it does look better with it though.
I strike a happy medium and instead of putting one up around the entire cabin, I only put one on the front of the cabin as adding one around the entire cabin would require redesigning the structure. Again, since the cabin has not been glued in place, it is an easy add. I cut a 2.5” section of 1/16” x 1/16” lumber and glue it in place, holding it with three clamps. I am going to add a note to my main cabin post bringing this to light so others can decide whether to add a fascia or not.
It is then painted white to match the cabin and I mark off four equally spaced holes along the fascia and drill four 0.6mm holes.
An eyebolt and ring are glued into each of the holes.
Next up were the so from the two mooring chocks, the bow and stern chocks, and the steering wheel, all from the Britannia metal pieces.
I used a few small files of different shapes to sand them free of the parting lines and gave them a couple of coats of primer.
3945
3946
View attachment 538239 View attachment 538240
And then Covid hit me again (and yes, I am vaccinated and bolstered). After a few days, I was up to some painting.
The chocks were easy as they are painted black.
I had wanted to dress up the steering wheel, so I used black, brown, and gold. They looked okay after they were done, but when I looked at a few pictures I had pulled up to give me ideas, I realized that in my Covid-infected brain I had mixed up where I was painting some of the black and some of the gold.
It sucked, but I repainted it and felt it looked better the second time around.
These five Britannia pieces are then glued in place.
View attachment 538243 View attachment 538244
Work time: 12.5 hours
Total work time: 305 hours
Lovely progress
7/30/25 to 8/15/25
Skylight
Companionway
3945
3946
Nice addings on the deck, Hugh. She is coming more and more to life.
Bluenose 20250901 Cliff Notes
I am switching things up again because of how long winded I am. My posted build log is going to be a lot less wordy and instructional, and only shows pictures of key steps or milestones in my build with just as sentence of two per picture.
As I did previously, my full (wordy) build log and pictures will be attached as a pdf at the end got those who want it.
After our club’s meeting last weekend, it was our first time trying to stream the meeting. The club meets at Rockler Wood Working (a local shop) and are fortunate enough to have made friends with two other clubs that also meet there: the Colorado Woodworkers Guide and the Front Range Woodturners. These are great groups that are allowing us to use their A/V equipment.
While we have a lot to learn about streaming, we jumped into it last weekend. We expect to open up the meetings to everyone by the January meeting – so stay tuned if there isn’t a meeting near you.
This build log is focused on more stuff on the deck, starting with what I should do directly in front of the main cabin. The plans have a note saying, “Sheathing over decking for stowage of barrels and other cargo.”
And it seems like it is about 50/50 in build logs as to something being in this spot of not, but there is no consistency on what should be here. But there are a couple of decent pictures of had actual Bluenose that show some barrels and cabinets.
So I made some barrels.
I know they are not perfect, but I like them. I then made two drums.
And then the stand for the barrels.
And attached the barrels and drums.
A quick placement of everything on the deck that I have created thus far gives me a quick And placed everything on the deck to see how it looks.
The mooring chocks at the stern look a little naked on the inside of the bulwarks as they are just the Britannia metal pieces sticking through from the outside, so I dressed them up by adding a small board.
And then painted and installed the main boom sheet.
And added more things to the stern of the deck.
The fife rail and bilge pumps are next.
Onto the bow and decided that I had better figure out the bowsprit, and found one in a box of dowels I inherited, one that is both long enough and the correct diameter, AND it has already been tapered like I need it, and the end is partially squared off!
Jackpot!!! Probably 90% of the job is done!
Last for this build is the galley stack.
Next up… the machinery and other stuff at the bow, but they may need to wait as my time in Colorado is dwindling before I leave for Mexico in early October.
Work time: 26 hours
Total work time: 331 hours
9/6/25 to 9/28/25
Saturday was our club’s workshop day, and I brought everything left that needs to be worked on for the machinery at the bow, including several Britannia pieces. While more talk was done than work, I did get the metal pieces cleaned up with my small metal files. They still need a second round of filing under magnifying glass but are already looking a lot better.
Back at home I did a real bonehead thing and ended up cutting my left pinky finger with a chainsaw. I know to use PPE, after all I was trained by my daughter who is a wild-land firefighter who is also a certified sawyer, but for some reason I wasn’t wearing gloves (or goggles or ear protection… heck I was even wearing shorts and sandals). Yes, definitely not my proudest moment. The good part is that in addition to being a bonehead, I am a lucky bonehead as all I needed was four stitches. And even though it was a small six-inch chainsaw, it could have been a lot worse.
So, listen to me when I remind you that you should always be safe.
Not too surprisingly that turned out to be all the work I could do on the Bluenose this stay at home as life threw a few curve balls my way before heading to Puerto Vallarta.
The biggest curve ball being that my big guy, my big fluff, my dog, suddenly passed away. He seemed pretty much fine on Thursday and he walked over the rainbow bridge on Saturday morning. Lucky was a great companion who it turns out had been suffering from advanced liver cancer. See ya on the other side my friend.
So that is it for now as I will be off to Vallarta in about a week. And while that means my work on the Bluenose is done for a while, it also means that my Molino will be coming out of dry dock.
Work time: 1 hours
Total work time: 332 hours
Quick update, even though I don't have any work to talk about. My wife and I have decided to move full time to Puerto Vallarta, Mexico, and are shooting to lreave on 2/27. Given that date and the state my Bluenose is currently in, I've made the difficult decision to NOT work on it. Yes, I've been home over a month and haven't touched her and won't as I feel she in in a good state to pack her up and transport her.
My thought is to pack her in a thick cardboard tube, one of those used for pouring concrete footings. I hope she fits in my carry-on bag, but if not, I'll figure it out. Gotta go, so much to do in the next month.
Good luck with your move to Mexico Hugo. I wish you and your family a safe move……..and your Bluenose. Cheers Grant
No Bluenose work to report, but after approximately 2 months and 2,000 miles, our packages arrived here in Puerto Vallarta. And the Bluenose survived the trip with NO damages!
I’m knee deep in my first rigging on my other build, the Molino so I’m not sure when I will switch gears and work on her, but I now have the option.
Hi Hugh.
Sorry I missed the club meeting. Very glad to hear your ship made it with no dings ! A true testament to your packing !
In reviewing your previous pictures, I would make a recommendation that is based on my IT background. Do not allow any drinks by the AV equipment. :)
I hope you are well !
Jeff
Hi Hugh.
Jeff
Totally agree with you about the drink. Kinda funny thing about the pic with the drink on the control table. The drink was not ours, nor was it at our meeting. It was the guy who runs the board for the woodworkers guild, at a woodworkers meeting. It was my first time observing how to run the board - and I wasn’t going to tell him how to run his equipment.
