Nice job on the monkey rail. I remember fretting about that for a long time.
Good morning Hug. Cool base for the stand. Cheers Grant2/25 to 2/28
The hull painting has gone fairly smoothly to this point but I’m switching gears to build the stand. I know it’s not really needed yet but the Rocky Mountain Shipwrights are going to have another show in April and I’m planning on displaying my Bluenose again. And given I’m heading to Vallarta in less than a month, I need to be at a good spot to not just display it, but also to hand it off to a friend who can display her and take care of her while I’m gone. Additionally I’m planning to show it during our club’s monthly meeting’s “show and tell” and then give it to Ralph afterwards. That means I have about 3 weeks to build the stand and finish painting the hull.
Like most things in this stage of my modeling, I haven’t scratch-built a stand.
I started by picking up a 3/16” x 4” board, a 14”x 6” “plaque” board, and some black felt at a local hobby store.
Using a profile gauge, I drew out where the 2 boards will go on the hull. I cut these drawings out and test fit them on the hull.
A few modifications including making them look more than just “square” boards and I transferred the patterns over to the 3/16” x 4” board and roughly cut them out.
Using my Goxawee (a Dremel-like device), I cleaned up the boards and test fit them against the hull. Once I was comfortable with their fit (plus a little wiggle room for the felt), I did a bit more cleanup work making them match each other as much as possible.
I squared them up and glued on 2 cross members.
Once dried, I measured and marked on the plaque board where it should be attached.
I drilled three small holes around 1/2” deep on each support and glued a small nail in each hole, leaving about 1/2” sticking out.
I line it up on the plaque board and marked where each nail was and drilled corresponding holes.
A little glue to the holes as well as the line where the support will go and on the support itself.
A little clean up and two coats of English Chestnut water-based stain.
Two coats of Pecan oil-based stain & poly with a light sanding in between coats.
Glue thin strips of black felt to the edges that the ship will rest on.
It’s my 1st scratch-built stand (okay, really anything) and I’m happy with the results. Now back to painting the hull.
Work time: 6.5 hours
Total work time: 218 hours
Always good to have a plan for setting the waterline on the hull, Hugh. Starting with the Rarlan pencil give a nice start.3/2 to 3/14
Today is the Rocky Mountain Shipwright’s workshop. I have two things I hope to do. The first is to organize my new “toolbox” and then mark the waterline.
Given I don’t set up a workshop at home and instead have made the decision to take stuff out whenever I want to work and then put everything away when I’m done for the day, having a nice toolbox has been on my mind for a while. I enjoy working in the main part of the house so I’m “around” my wife instead of going off by myself to work in the basement or back part of the house.
My new toolbox (which will mostly be duplicated in Mexico) are inexpensive plastic interlocking boxes. They come in a set of two boxes but I’ve added a third one in order to easily hold just about everything (except my painting supplies). Sure I got a joke or two about being able to store not just all my tools but my shoes too, but I think they’ll suit my needs.
I’ve separated my tools into 3 groups. Group 1 is stuff I use all the time, such as glue, caliper, pencils and xxx. Group 2 is basically everything to do with sanding and filling. And group 3 is stuff I don’t need too often but stuff I consider important. Right now this box has my waterline marker, my chamfer, and my plank bending tools.
I’ve debated if I should make this 3rd box for tools I don’t plan on duplicating in both Mexico and Colorado since I don’t use them enough to purchase two sets. This 3rd box could be transported fairly easily but if I go this route, I’ll need to make sure it’s stuff that can get through TSA at the airport as the goal is to not have to check luggage.
With the toolbox completed, I began to draw the waterline. I recently purchased a kit (came all the way from the Ukraine) and even though this was my 1st waterline, it went fairly smoothly with the only issue being that I needed to use a longer pencil than the golf pencil that was supplied with the kit.
The remaining time at the workshop I mapped out how I would paint the hull.
Tape off slightly above the waterline with 1/8” tape
I used some 1/8” tape just above the waterline and then painted the area right below the tape white.
- Paint the waterline white (multiple coats)
- Use 1/16” thin tape to cover white paint at the waterline (leave existing tape in place)
- Paint bottom half of hull “Hull Copper Red” (multiple coats)
- Remove 1/8” tape above waterline, leaving the thin tape in place
- Paint top half of hull black (multiple coats)
- Remove all remaining tape
- Paint entire hull clear satin (multiple coats)
Once dried, I put 1/16” tape directly next to the 1/8” tape covering up what will become the waterline.
For the lower half of the hull, I’m using a thinned down (with water) 50/50 mix of hull copper red (from Model Expo) and red clay acrylic from Michael’s. I had purchased the hull copper red a while back but wasn’t sure I’d have enough so on a whim I looked at the paint selection at Michael’s and found the red clay which was a very close match.
I did as couple of thin coats and am very pleased with the results other than two “spots” that showed up.
I cleaned up the bad spot, gave the hull a light sanding, and added another coat of red paint. Once dried, I removed the 1/8” tape above the waterline, leaving the 1/16” tape that covers the waterline in place.
The black only needed 2 coats, after which I removed the 1/16” tape at waterline). Very little paint bleeding.
Removed all remaining tape and while there is some bleeding, overall it looks good. I had been worried about the yellow and white lines because they were 1/16”, but even they had only minimal bleeding.
Each of the four colors needed multiple coats of touch up, mostly due the shakiness of my hands, however minor. It’s hard to touch up a 1/16” line with even just a little bit of shakiness.
Next up is the scroll work at the bow around the hawse holes as well as the attaching the hawse hole lips. The scroll work is painted yellow while the lips are painted black. A big shoutout to @Jeff T for sending me his leftover 3D printed scroll work. Hard to believe I’ve had them sitting in my box waiting for a little over 9 months.
After gluing the scroll work around the holes, I added a little yellow paint to “attach” the scrolls to the yellow line and then glued the hawse hole lips.
I’m going to wait until my return from Mexico (in June) to paint everything with the clear satin as I read that it’s best to wait for acrylic paint to fully cure before using varnish, and that could take up to 2 weeks. Being how dry it is here in Denver, I’m sure it would be cured in a lot less time, but with the RMSW’s meeting (and my show and tell of my Bluenose) on Saturday, I’m not going to push it just to say I’ve done it.
Now it’s off to Vallarta for a couple of months. See ya all on my Buccaneer/Molino build log.
Work time: 9.5 hours
Total work time: 227.5 hours
Especially with your 3D scroll workNice job with the painting. It turned out great!
An hour-long job that required your attention, Hugh. Because it is all in sight and attracts attention. So far so good!6/11 to 7/2
I’m back from Vallarta but it took almost a week for me to get my hands on my Bluenose… just too much stuff that needs my attention after being gone for over two months. I’m glad in many ways of being home, but I’ll be glad when it feels like home again.
First up is “what” exactly should I work on first? I decided to work on the chainplates followed by the eyelets.
Lots of written text (even for me) for what ended up a fairly small amount of work.
I liked the way Gary Brinker did them on his YouTube channel (BLUENOSE PART 19… Deadeyes & Chainplates) which is similar to what is shown in the instructions. Looks nice and the deadeyes are functional. The first one took about an hour (minus the three holes) and while I know I’d improve on the time and appearance, I wasn’t super impressed by my work. I also knew duplicating them (there are a total of 20) would be difficult and time consuming.
Then I built one like many builders do including the Suburban Ship Modeler. The first one took about 20 minutes (minus the three holes), and just like the other method I knew I’d improve upon the time and look, but I also felt in addition to looking better, they would be easier to duplicate.
The test came when I put both of these on the ship side by side. Bottom line the second method looked better. Plus I felt it would be easier to duplicate.
Building them is involved but fairly straightforward except for the drilling of the holes. More on that later.
I started building them out and I’m halfway done (8 large and 2 small) with the first part of the chainplates.
- Wrap wire around the deadeye
- Twist the ends of the wire tightly together
- Drill a hole about 1/4” from the end in the brass strip
- Feed the twisted ends through the hole in the brass strip
- Fold the end of the brass strip over upon itself trapping the twisted wire
- Measure and cut the chainplate to the proper length
- Cut the tip into a point
- Drill three (or two for the smaller ones) holes in the strip on the opposite end as the deadeye
- Secure the deadeye to the brass strip with a drop of superglue holding the twisted wire between the folds of the strip
The second part is drilling the holes for mounting them to the hull - each needs either 2 or 3 holes. Drilling the holes was the most difficult part of the overall process not just because drilling with a pin vice was proving to be difficult, but more importantly, if the hole wasn’t right in the middle of the strip, the brass strip would break when I folded it over. I used a push pin as a center punch, but the drilling was still daunting. I even tried using my GOXAWEE Rotary Tool (a Dremel-like tool) but it was still difficult.
View attachment 457010 View attachment 457011 View attachment 457012
I’m sure it would have been easier if I had a pair of magnifying glasses and a drill press - neither of which I currently have. I believe my local club (Rocky Mountain Shipwrights) has a drill press that I can borrow so I will wait on drilling the attachment holes.
Saturday June 15th was the club meeting where I picked up the drill press. Hopefully it will make things easier.
There was a learning curve on using the drill press (after all, I’m still drilling into a 1/16” strip), but I was able to finish the 2nd half of the chainplates (other than the 3 holes) in about an hour.
I build a small jig to help with the 3 holes… and yes it’s just stiff cardboard taped to a board but it does the trick.
As long as I take it slowly, I am able to drill the holes in one chainplate. I really need to focus on taking my time. One poorly drilled hole and I have to completely rebuild the chainplate. Of the 20, I end up needing to rebuild 5. The biggest take away is that with such a small drill bit, it tends to be flexible. When it touches the brass strip, it can very easily bend slightly and move off center. To resolve this, I have to tightly hold the strip against the table which is a bit difficult as the strip gets hot plus I have to hold it very close to the desired location of the hole… right next to the drill’s chuck. I end us using some old tweezers that have a bent tip.
After all 20 are drilled, I add a drop of super glue to where the twisted wire of the deadeye is located in folded strip. This goes fairly smoothly although the glue fills a few of the holes in the deadeyes. I’m able to drill these out on all of them except for one which I have to rebuild.
I then paint the brass black.
Looking at the rails that they will go through before being attached to the hull, I notice that while I made the slits for the chainplates for the foremast, I did not do it for the mainmast. And these slits actually need to go through two rails. Ugh. Since it’s been a few months since cut the slits, I looked back at my log to see if I could remember doing (and not doing) them, but somehow I didn’t write anything about them. I’m assuming I did them after painting the hull but before varnishing it.
Putting the slits in isn’t too difficult using a very narrow knife blade, but because of the way I made the chainplates (folding the strip over the twisted wire), the slits need to be more than slits; they need to be wide enough to let the folded section slide into the rail, at least partially. I use a variety of tools to make these holes in the rails; a small drill bit in a pin vice, two different files, one circular and the other flat, and the very narrow knife.
And even though I force myself to make these holes slowly, I still break through the side of the rail in a few places. These I close up with glue and a clamp.
View attachment 457016 View attachment 457017 View attachment 457019View attachment 457018
While test fitting the chainplates in place, I break one off them causing me to have to rebuild it.
Attaching the chainplates is fairly straightforward as they are glued and nailed to the hull. For the nailing, I get to use a pair of pin insertion pliers that I bought a while back from Micro-Mark. I only had about 60 pins to insert, but these pliers were great. I whole-heartily endorse them.
As for the super glue, I haven’t use it very much, so it is still a learning experience. One thing I learned from last time was to invest in some long skinny tips for the glue. This seems to have helped a lot.
After all of the chainplates are attached, I touch up the paint (black, white, and yellow) followed by a touch up of the satin varnish.
View attachment 457023 View attachment 457024View attachment 457026
The nail heads need a little touch up, but overall I’m pleased with them.
If I had a mulligan, I would have slid a card behind the chainplates before I attached them and touched up the black paint at that point. Live and learn.
Work time: 15 hours
Total work time: 244 hours
This is the exact reason I don’t keep track of hours…Work time: 15 hours
