- Dec 1, 2016
Thanks for that, Dave. That makes a lot of sense. One thing, though, how deep is the nip, around one third the width of the plank? Or make it the same nip each time?Taking the cardboard pattern i traced in on paper then drew the inside edge and the planking width
You can see the planking ends in a sharp point so they have to nib into the margin plank
starting with the first plank
as the planks get closer to the bow the point gets less and less
the end of the planks start where they meet the margin plank and go back to point of the last plank
View attachment 594628View attachment 594630
Incredible to think there were Travellers at a wood mill capable of making timber that long in the day. Just imagine tailoring out the 40-foot length of the planks.Laying out the decking i started with the plank tinted green. I did this because i wanted to run the plank against the main hatch coaming and straight from the bow to the cabin. You may notice there are no butt joints just one long plank. As was mentioned in an earlier post deck planks can run up to 40 feet long. I did wonder about that but i live in an area there are still massive trees and it is very possible to get a plank as long as 50 feet even today. This deck falls within the 40 foot range so i did not break the decking into smaller lengths.
by running the plank straight from the main hatch coaming it falls right on the edge of the notches for the windlass posts.
The deck was planked on both sides so now it is time to put in the gratings, windlass braces and posts. Then the center of the deck will be planked. Down the center planking will need to be adjusted around the posts.
At this stage the caulking makes the deck look messy, but when it is finished i will scrape the deck clean and smooth.
Some builders like to keep part of the deck open to show the beams and knees. I planked over all the structural work so you may wonder why bother if it is going to be hidden? Well, it was not hidden you saw the deck being built early on in the build, so you know what is under the planking. Because this is a class on building it was necessary to show how a deck is built and planked. It is not about the finished model.
