HMS Alert [1777] 1:48 POF by serikoff. (Two hulls: skeleton and fully rigged)
Deck. Nailing (imitation of plugs).
First, I made the joints on the boards with a straight blade. But since the power boards (which are a different color) were in short supply, I had to make real joints on them and then lay out the planks from there. Unfortunately, I made a small mistake, but in the end, I moved it to the place where the guns are... and it won't be visible. Although I blamed myself for it all day...
The only good thing is that everything looks good visually: there are no unnecessary joints, no irregularities, or violations of the rule of one joint every three solid boards, and that's truly pleasing.
Next comes the marking and the needling.
I start by making very small (barely noticeable) punctures along the entire belt. After checking for symmetry, I make the punctures deeper. If the first, weak puncture was slightly offset, I can correct this by making a second puncture, rather than making a second one, but rather by moving the hole closer to the first.
This process is the most important and painstaking... any mistake here is a visual flaw in the entire composition.
Then, carefully drill with a 0.5 mm drill bit.
Luckily, all the holes were made in the right places...
And the total number of such holes, as well as nails, will be 900.
A few close-ups for those closely monitoring the construction:
After sanding, I always check the surface for defects...
...and I fill them with regular PVA. And sand them again. As a result, the crack isn't stained as much by either oil or bitumen.
Here's the final result.
Without oil the nails are still hard to see, but I'm already happy with the result.
Deck . Nageln (Imitation von Dübeln).
Zuerst habe ich die Verbindungen der Bretter mit einem geraden Messer hergestellt. Da die Platinen für die Stromversorgung (die eine andere Farbe haben) aber knapp waren, musste ich sie mit richtigen Verbindungen versehen und die Bretter darauf auslegen. Leider ist mir ein kleiner Fehler unterlaufen, aber letztendlich habe ich die Platine an die Stelle verschoben, wo die Waffen stehen … und sie wird nicht sichtbar sein. Obwohl ich mich den ganzen Tag darüber geärgert habe …
Das einzig Gute daran ist, dass alles optisch gut aussieht: Es gibt keine unnötigen Fugen, keine Unregelmäßigkeiten oder Verstöße gegen die Regel, dass jeweils eine Fuge auf drei massive Bretter gesetzt wird, und das ist wirklich erfreulich.
Als Nächstes folgen das Markieren und das Vernadeln.
Ich fange damit an, entlang des gesamten Gürtels sehr kleine (kaum sichtbare) Löcher zu stechen. Nachdem ich die Symmetrie überprüft habe, vertiefe ich die Löcher. Fällt das erste, schwache Loch leicht versetzt war, kann ich dies korrigieren, indem ich ein zweites Loch hinzufüge, anstatt ein zweites zu stechen, sondern das Loch näher an das erste verschiebe.
Dieser Prozess ist der wichtigste und mühsamste... Jeder Fehler hier ist ein visueller Mangel in der gesamten Komposition.
Anschließend vorsichtig mit einem 0,5 mm Bohrer bohren.
Zum Glück wurden alle Löcher an den richtigen Stellen gemacht...
Die Gesamtzahl solcher Löcher sowie der Nägel beträgt 900.
Ein paar Nahaufnahmen für diejenigen, die die Bauarbeiten aufmerksam verfolgen:
Nach dem Schleifen überprüfe ich die Oberfläche immer auf Mängel...
…und ich fülle sie mit normalem PVA-Kleber. Anschließend schleife ich sie erneut. Dadurch wird der Riss weder durch Öl noch durch Bitumen so stark verfärbt.
Hier ist das Endergebnis.
Ohne Öl sind die Nägel zwar noch schwer zu erkennen, aber ich bin mit dem
Wunderbarer Eindruck deiner Technik. Sehr sauber gearbeitet. Erstklassig erklärt und visualisiert. Das Ergebnis spricht für sich. Einer der besten Bauberichte, die ich gelesen habe. Dein Baubericht und all die „ Teilberichte „ gleichen einem Studium. Eine Anleitung für weltklasse Modellbau. Danke, dass Du uns hier jeden Schritt so ausführlich zeigt und erklärst.
You should be happy that I don’t live close to you. Otherwise you would have an unexpected apprentice that you couldn’t get rid of . Beautiful work, as always!
Ahah, thank you. Technology now makes it easier to learn from others. I'm glad I can help. And I'll be happy if all my "students" one day surpass their "teacher" many times over. Ahahahaha
Vielen Dank für das Lob. Und ich bin sicher, es gibt viele Modellbauer, die es viel besser machen als ich… Meine Stärke ist, dass ich versuche, meine Vorgehensweise zu erklären. Ich habe einmal Modellbauer getroffen, die ebenfalls ihre Erfahrungen teilten, und mir wurde klar, dass die Leute mehr daran interessiert sind, zu verstehen und zu sehen, wie man es nachbaut, als das schönste Ergebnis zu sehen.
(En) Thank you for the high praise. And I'm sure there are many modelers who do much better than me... My strength is that I try to share how I do everything. I once met modelers who also shared their experiences, and I realized that people are more interested in understanding and seeing how to replicate it, rather than seeing the most beautiful result.
Waterways. 1/2
Since the anatomy drawings don't really show normal views of this unit (not to mention the lack of drainage channels), I'll use the diagram from the anatomy of the Royal Caroline 1749 as a reference.
First, I dismantled the temporary waterway and made a simple jig to create a new one.
In order to understand which cut would look better, I tried it from different sides.
The principle of jig is simple. You need to cut a section of the workpiece diagonally. And then you just need to create a slanted surface.
This jig will be needed for the second set (for the first hull).
Next, I bent the blanks using a simple method. I dipped them in boiling water and then ironed them into the desired shape. I didn't try too hard, the main thing was to bend them where the radius was largest.
After removing the deck stop, I installed the deck inside the hull.
The rest is in the next part...
Waterways. 2/2
To make adjustments, I made a removable keelson top. Now I need to make room for it in the waterways.
I added a couple more plugs to the outer chord of the 0.5mm planks (as usual). And two 0.8mm plugs at the ends of the waterways. These plugs are larger because they cover bolts, not nails, which secure the waterways (top to bottom) to the beams and (from inside to outside) to the frames. This creates a unified framework, as the waterways weren't merely decorative, but were crucial for achieving the hull's longitudinal and transverse strength.
Next, everything is standard: injection, start with a drill of a smaller diameter, and finish with a drill of the required diameter (0.8 mm).
After securing the toothpick (without glue), I apply glue to the back. I bite off the toothpick and sand it down to a level surface.
Scuppers (inner part).
*A few words about the plugs on the waterways. They are located in the center of the beam, as the bolt passed through both parts. We can't see the bolts that connect the waterway and the frames, as they are covered by deck planks.
So, what are scuppers? They are lead pipes through which water that entered the ship's side exited. Since the Alert had a very low side, this detail was very important. Ships of this class could have 4-5 pairs of scuppers.
The scuppers were not supposed to hit the beams or top timbers, frames, gun ports, or other hull elements.
In the photo below, I've indicated the positions of the pumps and the lowest points on the deck (I used balls, and they found these points). These points were located under the gun ports, where scuppers couldn't be located. Therefore, I didn't move the second-to-last scuppers aft (to reduce their number to four pairs), but rather placed them as close as possible to these points. However, this left a large area aft (especially considering the low frame of the rear grille). Therefore, I had to add a fifth pair (the rear one). But given the small diameter of the scuppers (to avoid brittleness of the planks they pass through) and the low sides (which didn't provide protection from waves at high heels), five pairs is quite realistic. Let me remind you that these details are essentially absent from the anatomy, so all planning is a reconstruction based on a similar situation of similar ships.
So, there's a 1.6 mm hole. It's angled, not tied to any specific value, since the scuppers will be composite: internal (on the deck) and external (on the hull). Today, we'll be talking about the internal ones.
I used 1.6mm brass tube.
After I'd angled it correctly, I'd push it through the hole and use a sharpened file to slightly increase the diameter by stretching it. This made the tube fit more snugly. I held it so the cut surface was flush with the deck surface and glued it to the back with CA gel.
After trimming off the excess, I polished the surface. I recommend leveling the surface right away so you don't have to sand too much, otherwise you'll leave marks on the polished deck.
And here's the result:
It's not a given that these elements will be very visible, as there will be cannonball holders above them. That's why I didn't bother with the funnel shape, flaring the metal... this shape is more than sufficient at this scale.
Next comes the remaining 8 pieces... and creating the outer parts that will be fixed to the hull. This is also a consideration. Scuppers, especially on low-sided ships, had check valves. These are rectangular pieces of leather that covered the openings. They dangled freely and easily let water pass from the inside out, but when a wave hit from the outside, they sealed the pipe tightly, preventing water from spurting out. So the question is... how to implement this. Should I make this valve... then it would cover the opening and all the work on the scupper... Or should I ignore the valve and show the design of this element. The downside of the valve is that it's difficult to show it well, especially at this scale... so I'm more inclined to go without the valve. Considering that many models don't always have scuppers. ;) Speechless
Waterways. 2/2
So, you will have one model to show what the insides look like and the other that will be fully planked I believe is what you said you were going to do with these. What about putting the valve on the one that is planked and leaving it off of the one that is not? As for modeling the leather valve, what about a piece of silk fabric might lay down like it needs to. You might have to dye it to get the color you want, if it will work.
It's a good idea... but I need to think about it some more... and, of course, experiment. Whichever option I like best, I'll keep.
A tragedy for our hobby...
I experienced something similar several years ago, when my forum was effectively destroyed by the war. All the photos from all the reviews disappeared there, too. As many already know, hackers destroyed the forum of our colleagues at Model Ship World. This is a huge tragedy for our hobby. That's why I created another backup review on Google Blog so that all the information would be stored not just on one forum (or two) or just photos somewhere on a hard drive, but so that it would be a complete review that could be easily restored. What happened is very sad, and I am speechless. After all the events in Ukraine, the war, and other misfortunes, it's hard for me to accept grief, as we've become accustomed to it... but my heart aches for such a loss. I'm sure everything will recover... it will take a long time, but we must move on. I really hope SoS won't be subject to a similar hacker attack, and I hope the security will be reconsidered after what happened to my colleagues... but to stay connected, I'm leaving my website (which I update regularly whenever possible) open for those who follow me and my builds. For now, I've migrated the Alert review (but not all of it yet) from the old site (which was also affected) to the new one, and I'll migrate all the information over time. This will serve as my backup repository for complete reviews.
Made 3 more remaining Scuppers...
...and 5 more on the other side.
And I made all the Scuppers on the hull in the same way.
I checked how the pipe would look flush with the boards, and I wasn't very happy with it. So I made it with a slightly protruding edge, which is more logical, so that water will fall off the rim and not run down the side.
The details are not large and are practically invisible in the general plan, but in macro mode it’s a different matter:
Photographed in the setting sun - the color is a little warmer than usual.
Masterfully preformed
Sehr präzise und sauber durchdacht.Danke fürs Zeigen
Thank you, friends, for your interest. While I'm waiting for the lamp, I can't make the lighting, and while I'm waiting for the motor to rotate it, I can't do the copper plating, so I've decided to continue working on the first hull, and I'll show you the results soon.
