HMS Alert [1777] 1:48 POF by serikoff. (Two hulls: skeleton and fully rigged)
Deck. Nailing (imitation of plugs).
First, I made the joints on the boards with a straight blade. But since the power boards (which are a different color) were in short supply, I had to make real joints on them and then lay out the planks from there. Unfortunately, I made a small mistake, but in the end, I moved it to the place where the guns are... and it won't be visible. Although I blamed myself for it all day...
The only good thing is that everything looks good visually: there are no unnecessary joints, no irregularities, or violations of the rule of one joint every three solid boards, and that's truly pleasing.
Next comes the marking and the needling.
I start by making very small (barely noticeable) punctures along the entire belt. After checking for symmetry, I make the punctures deeper. If the first, weak puncture was slightly offset, I can correct this by making a second puncture, rather than making a second one, but rather by moving the hole closer to the first.
This process is the most important and painstaking... any mistake here is a visual flaw in the entire composition.
Then, carefully drill with a 0.5 mm drill bit.
Luckily, all the holes were made in the right places...
And the total number of such holes, as well as nails, will be 900.
A few close-ups for those closely monitoring the construction:
After sanding, I always check the surface for defects...
...and I fill them with regular PVA. And sand them again. As a result, the crack isn't stained as much by either oil or bitumen.
Here's the final result.
Without oil the nails are still hard to see, but I'm already happy with the result.
Deck . Nageln (Imitation von Dübeln).
Zuerst habe ich die Verbindungen der Bretter mit einem geraden Messer hergestellt. Da die Platinen für die Stromversorgung (die eine andere Farbe haben) aber knapp waren, musste ich sie mit richtigen Verbindungen versehen und die Bretter darauf auslegen. Leider ist mir ein kleiner Fehler unterlaufen, aber letztendlich habe ich die Platine an die Stelle verschoben, wo die Waffen stehen … und sie wird nicht sichtbar sein. Obwohl ich mich den ganzen Tag darüber geärgert habe …
Das einzig Gute daran ist, dass alles optisch gut aussieht: Es gibt keine unnötigen Fugen, keine Unregelmäßigkeiten oder Verstöße gegen die Regel, dass jeweils eine Fuge auf drei massive Bretter gesetzt wird, und das ist wirklich erfreulich.
Als Nächstes folgen das Markieren und das Vernadeln.
Ich fange damit an, entlang des gesamten Gürtels sehr kleine (kaum sichtbare) Löcher zu stechen. Nachdem ich die Symmetrie überprüft habe, vertiefe ich die Löcher. Fällt das erste, schwache Loch leicht versetzt war, kann ich dies korrigieren, indem ich ein zweites Loch hinzufüge, anstatt ein zweites zu stechen, sondern das Loch näher an das erste verschiebe.
Dieser Prozess ist der wichtigste und mühsamste... Jeder Fehler hier ist ein visueller Mangel in der gesamten Komposition.
Anschließend vorsichtig mit einem 0,5 mm Bohrer bohren.
Zum Glück wurden alle Löcher an den richtigen Stellen gemacht...
Die Gesamtzahl solcher Löcher sowie der Nägel beträgt 900.
Ein paar Nahaufnahmen für diejenigen, die die Bauarbeiten aufmerksam verfolgen:
Nach dem Schleifen überprüfe ich die Oberfläche immer auf Mängel...
…und ich fülle sie mit normalem PVA-Kleber. Anschließend schleife ich sie erneut. Dadurch wird der Riss weder durch Öl noch durch Bitumen so stark verfärbt.
Hier ist das Endergebnis.
Ohne Öl sind die Nägel zwar noch schwer zu erkennen, aber ich bin mit dem
Wunderbarer Eindruck deiner Technik. Sehr sauber gearbeitet. Erstklassig erklärt und visualisiert. Das Ergebnis spricht für sich. Einer der besten Bauberichte, die ich gelesen habe. Dein Baubericht und all die „ Teilberichte „ gleichen einem Studium. Eine Anleitung für weltklasse Modellbau. Danke, dass Du uns hier jeden Schritt so ausführlich zeigt und erklärst.
You should be happy that I don’t live close to you. Otherwise you would have an unexpected apprentice that you couldn’t get rid of . Beautiful work, as always!
Ahah, thank you. Technology now makes it easier to learn from others. I'm glad I can help. And I'll be happy if all my "students" one day surpass their "teacher" many times over. Ahahahaha
Vielen Dank für das Lob. Und ich bin sicher, es gibt viele Modellbauer, die es viel besser machen als ich… Meine Stärke ist, dass ich versuche, meine Vorgehensweise zu erklären. Ich habe einmal Modellbauer getroffen, die ebenfalls ihre Erfahrungen teilten, und mir wurde klar, dass die Leute mehr daran interessiert sind, zu verstehen und zu sehen, wie man es nachbaut, als das schönste Ergebnis zu sehen.
(En) Thank you for the high praise. And I'm sure there are many modelers who do much better than me... My strength is that I try to share how I do everything. I once met modelers who also shared their experiences, and I realized that people are more interested in understanding and seeing how to replicate it, rather than seeing the most beautiful result.
Waterways. 1/2
Since the anatomy drawings don't really show normal views of this unit (not to mention the lack of drainage channels), I'll use the diagram from the anatomy of the Royal Caroline 1749 as a reference.
First, I dismantled the temporary waterway and made a simple jig to create a new one.
In order to understand which cut would look better, I tried it from different sides.
The principle of jig is simple. You need to cut a section of the workpiece diagonally. And then you just need to create a slanted surface.
This jig will be needed for the second set (for the first hull).
Next, I bent the blanks using a simple method. I dipped them in boiling water and then ironed them into the desired shape. I didn't try too hard, the main thing was to bend them where the radius was largest.
After removing the deck stop, I installed the deck inside the hull.
The rest is in the next part...
Waterways. 2/2
To make adjustments, I made a removable keelson top. Now I need to make room for it in the waterways.
I added a couple more plugs to the outer chord of the 0.5mm planks (as usual). And two 0.8mm plugs at the ends of the waterways. These plugs are larger because they cover bolts, not nails, which secure the waterways (top to bottom) to the beams and (from inside to outside) to the frames. This creates a unified framework, as the waterways weren't merely decorative, but were crucial for achieving the hull's longitudinal and transverse strength.
Next, everything is standard: injection, start with a drill of a smaller diameter, and finish with a drill of the required diameter (0.8 mm).
After securing the toothpick (without glue), I apply glue to the back. I bite off the toothpick and sand it down to a level surface.
Scuppers (inner part).
*A few words about the plugs on the waterways. They are located in the center of the beam, as the bolt passed through both parts. We can't see the bolts that connect the waterway and the frames, as they are covered by deck planks.
So, what are scuppers? They are lead pipes through which water that entered the ship's side exited. Since the Alert had a very low side, this detail was very important. Ships of this class could have 4-5 pairs of scuppers.
The scuppers were not supposed to hit the beams or top timbers, frames, gun ports, or other hull elements.
In the photo below, I've indicated the positions of the pumps and the lowest points on the deck (I used balls, and they found these points). These points were located under the gun ports, where scuppers couldn't be located. Therefore, I didn't move the second-to-last scuppers aft (to reduce their number to four pairs), but rather placed them as close as possible to these points. However, this left a large area aft (especially considering the low frame of the rear grille). Therefore, I had to add a fifth pair (the rear one). But given the small diameter of the scuppers (to avoid brittleness of the planks they pass through) and the low sides (which didn't provide protection from waves at high heels), five pairs is quite realistic. Let me remind you that these details are essentially absent from the anatomy, so all planning is a reconstruction based on a similar situation of similar ships.
So, there's a 1.6 mm hole. It's angled, not tied to any specific value, since the scuppers will be composite: internal (on the deck) and external (on the hull). Today, we'll be talking about the internal ones.
I used 1.6mm brass tube.
After I'd angled it correctly, I'd push it through the hole and use a sharpened file to slightly increase the diameter by stretching it. This made the tube fit more snugly. I held it so the cut surface was flush with the deck surface and glued it to the back with CA gel.
After trimming off the excess, I polished the surface. I recommend leveling the surface right away so you don't have to sand too much, otherwise you'll leave marks on the polished deck.
And here's the result:
It's not a given that these elements will be very visible, as there will be cannonball holders above them. That's why I didn't bother with the funnel shape, flaring the metal... this shape is more than sufficient at this scale.
Next comes the remaining 8 pieces... and creating the outer parts that will be fixed to the hull. This is also a consideration. Scuppers, especially on low-sided ships, had check valves. These are rectangular pieces of leather that covered the openings. They dangled freely and easily let water pass from the inside out, but when a wave hit from the outside, they sealed the pipe tightly, preventing water from spurting out. So the question is... how to implement this. Should I make this valve... then it would cover the opening and all the work on the scupper... Or should I ignore the valve and show the design of this element. The downside of the valve is that it's difficult to show it well, especially at this scale... so I'm more inclined to go without the valve. Considering that many models don't always have scuppers. ;) Speechless
Waterways. 2/2
So, you will have one model to show what the insides look like and the other that will be fully planked I believe is what you said you were going to do with these. What about putting the valve on the one that is planked and leaving it off of the one that is not? As for modeling the leather valve, what about a piece of silk fabric might lay down like it needs to. You might have to dye it to get the color you want, if it will work.
It's a good idea... but I need to think about it some more... and, of course, experiment. Whichever option I like best, I'll keep.
A tragedy for our hobby...
I experienced something similar several years ago, when my forum was effectively destroyed by the war. All the photos from all the reviews disappeared there, too. As many already know, hackers destroyed the forum of our colleagues at Model Ship World. This is a huge tragedy for our hobby. That's why I created another backup review on Google Blog so that all the information would be stored not just on one forum (or two) or just photos somewhere on a hard drive, but so that it would be a complete review that could be easily restored. What happened is very sad, and I am speechless. After all the events in Ukraine, the war, and other misfortunes, it's hard for me to accept grief, as we've become accustomed to it... but my heart aches for such a loss. I'm sure everything will recover... it will take a long time, but we must move on. I really hope SoS won't be subject to a similar hacker attack, and I hope the security will be reconsidered after what happened to my colleagues... but to stay connected, I'm leaving my website (which I update regularly whenever possible) open for those who follow me and my builds. For now, I've migrated the Alert review (but not all of it yet) from the old site (which was also affected) to the new one, and I'll migrate all the information over time. This will serve as my backup repository for complete reviews.
Made 3 more remaining Scuppers...
...and 5 more on the other side.
And I made all the Scuppers on the hull in the same way.
I checked how the pipe would look flush with the boards, and I wasn't very happy with it. So I made it with a slightly protruding edge, which is more logical, so that water will fall off the rim and not run down the side.
The details are not large and are practically invisible in the general plan, but in macro mode it’s a different matter:
Photographed in the setting sun - the color is a little warmer than usual.
Masterfully preformed
Sehr präzise und sauber durchdacht.Danke fürs Zeigen
Thank you, friends, for your interest. While I'm waiting for the lamp, I can't make the lighting, and while I'm waiting for the motor to rotate it, I can't do the copper plating, so I've decided to continue working on the first hull, and I'll show you the results soon.
Gun ports sill. (1st hull)
While I'm still working on the second hull's lighting and copper plating, I've decided to continue working on the first hull.
As they say, a good idea comes later... but it's what it is. If I were building the hull now, with the knowledge I have now, I would do everything differently. More on that later (this information will at least help those just starting to assemble frames, so they can at least get everything right from the start, like in anatomy). But I'll be adjusting what I can now as construction progresses.
I used a template to mark the marking line. Tip: use one template for both sides—this will reduce the margin of error when using a second template on the other side due to imprecise alignment of the two templates. Insert the wedges from the inside out—this will press the template against the hull.
I draw only one (specified) line!
I will cut off some frames (in the port area to replace them with new parts) or cut and move frames into the desired position.
Correction!! Later I moved the port forward a bit.
All these parts will be further refined, and their arched shape will be polished later. Therefore, I didn't see any reason to focus too much on their aesthetics. The main thing is the correct side walls, front, and inner (they're all in order). The top will still be trimmed to level, and the bottom (where the glue is) will be completely covered with planks.
But if I were doing it all over again (from scratch), I would integrate these parts into the frames (making windows in them) before sanding. And then sand the hull simultaneously: the frames and gun ports.
A logical question: why don't I do it as in the kit instructions? Firstly, I absolutely don't like the solution with the railings and window sills that the kit suggests. Secondly, due to errors in the frame placement, the railing topstems (posts) don't line up, and it's very noticeable. Therefore, when I make my own version of the railing, I'll place the posts in the right places, as I did on the second hull. But the steps there are slightly different, so I've essentially already come up with two different ways to implement this area.
Another mistake in the laying was that the second frame was too close to the first. And with this distance, it was impossible to install the bowsprit. I would have glued frame #2 further down, but since it was already glued, I simply moved it.
Then I installed 1 mm spacers under the template and used a scalpel to mark a second line. This line is no longer the center of the sill, but the joint line of the first plank with this sill. I marked this line because I would be gluing the first board first, followed by the others, and then the sill itself, which will have a complex prefabricated shape (like the one in the second hull, but slightly different).
This line was also needed to correctly position the sill of the first port. The rear wall coincides with this line, and the front is 1 mm lower. The plane can easily be determined by placing a square block on both ports simultaneously.
Now, about what I would have done right away if I were just starting to assemble the hull from frames:
1. I would calculate and glue all the frames so that their upper parts or top timbers completely coincide with the actual positions of the railing posts and all the gun ports. If necessary, I would connect the lower and upper parts of a frame not so that they are in the same plane, but rather form steps and can thus be shifted to the desired positions at the top (as is essentially implemented in anatomy).
2. I would initially make paired frames in both the fore and aft sections, as in the photo below.
It wasn't much work, just like it would have been if the kit manufacturer had done it right away. It's a shame they didn't (with all due respect to the effort that went into creating the kit, which is actually quite good!).
3) I would also narrow the top frames from 4mm to 3mm, so that the railing posts would be all 3mm thick. Not like in the kit—4mm frames and 3mm top timbers.
4. I also don't like the implementation of the detail under the aft frames. I have a couple of ideas for how to replace it, but since it's too late for me, I'll just cover this area with partial planking.
I forgot to clarify... since I can't move the frames without reducing them, these areas will be covered with planks both from the outside and inside. Therefore, if you want these areas to be exposed, you need to do it correctly from the start, during hull assembly.
Next in line is fixing the planks (boards) below the railings-window sills and then the railings themselves...
Diese Linie war auch notwendig, um die Schwelle des ersten Anschlusses korrekt zu positionieren. Die Rückwand fällt mit dieser Linie zusammen, die Vorderseite liegt 1 mm tiefer. Die Ebene lässt sich leicht bestimmen, indem man einen quadratischen Block gleichzeitig auf beide Anschlüsse legt.
Nun zu dem, was ich sofort getan hätte, wenn ich gerade erst mit dem Zusammenbau des Rumpfes aus den Spanten begonnen hätte:
1. Ich würde alle Rahmen so berechnen und verleimen, dass ihre oberen Teile bzw. die oberen Balken exakt mit den Positionen der Geländerpfosten und aller Geschützpforten übereinstimmen. Falls nötig, würde ich die unteren und oberen Teile eines Rahmens nicht in einer Ebene verbinden, sondern stufenförmig, sodass sie oben in die gewünschte Position verschoben werden können (ähnlich wie in der Anatomie).
2. Ich würde zunächst paarweise Rahmen im vorderen und hinteren Bereich anfertigen, wie auf dem Foto unten zu sehen.
Es war nicht viel Arbeit, genauso wie es der Fall gewesen wäre, wenn der Hersteller des Bausatzes es gleich erledigt hätte. Schade, dass sie es nicht getan haben (bei allem Respekt vor der Mühe, die in die Entwicklung des Bausatzes geflossen ist – der ist nämlich wirklich gut!).
3) Ich würde außerdem die oberen Rahmen von 4 mm auf 3 mm verjüngen, sodass die Geländerpfosten alle 3 mm dick wären. Nicht wie im Bausatz – 4 mm Rahmen und 3 mm obere Balken.
4. Auch die Ausführung der Details unter den Achterspanten gefällt mir nicht. Ich hätte ein paar Ideen, wie man sie ersetzen könnte, aber da es für mich zu spät ist, werde ich diesen Bereich einfach teilweise beplanken.
Ich habe vergessen zu erwähnen, dass ich die Spanten nicht versetzen kann, ohne sie zu kürzen. Daher werden diese Bereiche sowohl von außen als auch von innen mit Planken verkleidet. Wenn diese Bereiche also sichtbar bleiben sollen, muss dies von Anfang an, während der Rumpfmontage, korrekt ausgeführt werden.
Als nächstes werden die Bretter unterhalb der Geländer-Fensterbänke und anschließend die Geländer selbst befestigt...
Eine Arbeit wie bei einem Archeologen . Es ist herrlich deinem Baubericht und deinen Recherchen zu folgen. Sehr durchdachte und anschauliche Lösungen. Jeder der die Alert bauen möchte, bekommt durch diesen Baubericht die perfekte Anleitung.
I would not change the framing of the can't frames.
There is no original framing design of this class. In my opinion the design in the AotS is only a possible solution. It's really possible that the cutter did not have double frames.
Vielen Dank für Ihre freundlichen Worte. Der Prozess der Recherche und der Suche nach der Wahrheit ist nicht weniger interessant als der Bau selbst.
Perhaps, given the numerous errors in the anatomy, there's some logic to my approach. And the changes I'm proposing are specifically related to the position of the top timbers (railing posts or gun ports). Everyone decides for themselves; I'm simply suggesting how I would do it if I were starting this kit over again. Moreover, these changes aren't particularly complex. After gluing all the frames and dry-assembling, just a few tweaks could be made to improve both the overall appearance of the hull and the functionality of the railing posts.
In anatomy, it is generally shown that paired frames go only in the lower part of the hull, and in the set - to the very top and this is already a significant difference, but if you follow the same logic in construction, then it is more logical to make double frames everywhere and at the same time shift several frames for the correct position of their upper parts
Ich würde die Gestaltung der "Kann nicht"-Rahmen nicht ändern.
Für diese Klasse gibt es keine Original-Rahmenkonstruktion. Meiner Meinung nach ist die Konstruktion im AotS nur eine mögliche Lösung. Es ist durchaus möglich, dass die Schneidemaschine keine Doppelrahmen besaß.
Hallo Christian,
Welche Quellen zur Warnung nutzt Du bitte?
Gruß
