Annie Buck Chesapeake deadrise oyster / crab working boat Build Log
Bryn Mawr PA US
Build Log - "Annie Buck" Chesapeake deadrise oyster / crab working boat (scratch build from plans)
Plans from "Fundamentals of Model Boat Building" by John Into & Nancy Price (Schiffer Books 2010). This is a very basic wooden waterline model of a common fishing boat used from the Chesapeake Bay of Maryland down to the Outer Banks of North Carolina. The Chesapeake deadrise stern is different from other Chesapeake boats with a "drake-tail" like the Hooper's Island drake tail from the Eastern Shore, another workhorse of the Mid-Atlantic fishing industry.
The Chesapeake deadrise oyster / crab working boat is my first build using a scroll saw, chisels, rasps and wood files and other woodworking tools. Having fun learning to shape wood components and trying different types of wood, including basswood, pine and balsa wood. I've watched alot of videos about using the scroll saw, power tool safety, wood chisels, and different woods. I can see how using a fine saw like the scroll saw can give great results in detailing and fine carving, but can be temperamental if youre using the wrong pin blade. I'm going slowly, so this build may take a while, but it is a nice boat to build.
Both halves of the hull frame were cut from pine stock and I fabricated other parts with 2mm basswood sheets, 1/4 inch basswood planks, and 1mm and 2mm cardboard stock (cigar box thickness).
I cut the pine so that I can save the cuttings for other projects. It's a really workable wood stock a bit harder than the basswood. Careful not to use balsa wood for any structural parts, but will use balsa to build up the cabin and pilot house coamings and the engine blocks.
Made vertical and horizontal slices in the pine blocks to rough cut the 2 hull frames. Then used the Dremel-clone tool, rasps and files to fine detail frames, the gingerbread (cabin sides), the cabin block and the pilot block. Also used 80, 120 and 220 grit sandpaper and blocks.
Tomorrow I will use a plane to shape the hull chines and waterlines, then glue and clamp the 2 hull frames and the transom with Titebond II overnight. The challenge will be to plane a hull shape that has realistic lines / chines from stem to stern. The original Annie Buck had a fiberglass form hull, so wood may not be as pliable.
I will also use chisels and cutting tools to shape the insides of the wales and the surface deck. The plans give you a lot of add-on options (deck furnishings like cleats, bollards, and a mast), to make the Chesapeake deadrise oyster / crab working boat more of a realistic build.
You appear to be so well organized! :) I feel so inferior:(:(
Thanks for sharing!
AllanKP69 - One thing I learned is that the scroll saw gets sawdust all over my shop, so the portable vacuum is always ready! I need to figure out how to hook up my shop vac to the scroll saw dust handler. I did manage to break 2 saw blades trying to find a blade that can cut 1.5 inch pine boards, so still learning the limits of the saw.
2. Build Log "Annie Buck" Chesapeake deadrise oyster / crab working boat
Today was all about getting the 2 sides of the hull assembly worked with a planer and filing / sanding tools. After watching some videos on YouTube, I jumped in with the mini-planer for the first time. Amazing how you can plane super smooth surfaces with the right cutting angle. I was going for good curling of the shavings after adjusting the planer blade. I am very happy that I was able to preserve the cut notch (.5 mm) on the inner hull that separates the pilot house from the cockpit about 4 inches up from the transom.
I got the 2 hull forms to be nearly identical to the eye, knowing that there will be plenty of time to fair the hull before we're through. I made a mistake by jumping ahead and cutting through the last inch of pine block, not realizing that that impacts how I glue the 2 sides of the frame together.
I made a crude jig to glue in the transom to a strong bottom (like a strong back) using a 1/4 inch basswood plank. I used rubber bands to hold in the transom and clamps to hold the 2 hull forms together overnight. Titebond II for the wood joints and Elmer's Tacky Glue to attach the paper plans to the pine blocks. We'll see how good the bond is overnight because tomorrow will involve using chisels for the first time at the waterline level and inside the coamings on deck.
I'm making nice straight cuts with the scroll saw now and I'm rotating different pinned saw blades depending on the thickness and hardness of the wood stock. Making slower cuts for softer basswood and balsa wood and using a higher blade speed for pine. We'll see how the new poplar wood stock works under the scroll saw.
The revelation of the day is how liberating doing scratch builds like this Chesapeake deadrise can be (as opposed to building a wooden boat kit). I'm feeling the grain of the wood, cutting only along the grain and feeling the difference between different types of wood. I still make mistakes (like cutting the transom block too short twice), but I feel like I can always recover by cutting more wood.
Sounds weird but I feel like I'm crafting the wood instead of just moving around or cutting the wood. I went to the craft store today and was actually excited to buy about 12 board feet of 1/4 inch and 1/2 inch poplar wood boards.
After slogging through my last build, which was an Artesiana Latina kit with no instructions or design plans (just wordless videos), this build from the "Fundamentals of Boat Building" book by Into & Price is refreshing. Every step has a detailed picture, it tells you all the tools you need and the plans tell you exactly where to cut and where to glue.
I liked this publisher, Schiffer Publishing, so much that I ordered 2 other scratch build books on The Spritsail Skiff and The Skipjack, both by Steve Rogers and Patricia Staby-Rogers. Both are as detailed as the Chesapeake deadrise, and I may build one or the other after my next build, which will be the Muscongus Bay Lobster Smack from Midwest (who hasnt built the Lobster Smack?). I just ordered the Schiffer book on the Menhaden Steamer (at 1/2 inch scale) which offers a 56-inch scratch build steamer model! Also written and designed by Rogers and Staby-Rogers.
The challenges for tomorrow include scribing / carving the chine line from stem to stern, building up the cabin and the pilot house, and chiseling off the strong bottom. I have been practicing with 3 types of chisels by carving ducks out of 3-inch basswood blocks. I may need to get a mallet like in the book - I have a hammer in the shop but its not the right tool for the job...
One of those boats motors past my deck pretty much daily - heading out to the Bay and back.
I decided to work Tulip Poplar for hidden parts originally - my first 8x4 plank was mostly heartwood - lots of pier piling brown and olive drab - but my next planks are almost all sapwood and the yellow passes for scale Oak or Pine decking.
Compared to Black Cherry and Hard Maple it carves like air. Once you have worked it, I am surprised that you would go near Basswood again.
The price cannot be bettered for a hardwood - Cygnus changes $3.00 BF for rough 4x4 and $4.00 BF for 12x4.
For bending - the ammonia used for that is anhydrous NH4 - industrial, explosive, poisonous pure gas at 1 atm. All the liquid cleaner version does is denature the surface of the wood.
You might consider replacing that barrel in your iron with the Chinese knock off of the old classic Aeropiccola bending head:
It may just slip in if it is a 936 solding iron - $20 at Amazon - Chinese aeropiccola bender.jpg
A simple dimmer switch may give you control over the temp -
The Chesapeake Bay Maritime Museum store at St. Michaels MD used to sell actual blue prints for some classic Bay craft - way back when - I scarphed up all that I could get. No word about any plans on their website https://cbmm.org/shopping-at-cbmm/
Looks like you're off to a good start! Scratch building can offer its own challenges, but I've found it can also be very rewarding.
Thanks Jacques Cousteau! I like these plans from Schiffer Books...so much easier to follow step by step directions and pictures for each step than my last build from Artesiana Latina. I am also enjoying my scroll saw and mini-planer and the new ways to craft wood they offer. Now I'm thinking my next build might be a scratch half-hull model of a historic yacht using different woods stocks. No rigging!
It may just slip in if it is a 936 solding iron - $20 at Amazon - View attachment 599000
Thanks Jaager! All good recommendations. I'm going to check out Cygnus for maple, cherry, pine, and pear stock. The only wood I've ever bought online was cheap planking stock from Model Expo. Also, I don't love my plank bender, so maybe switching up the bending head might improve it. I am enjoying these scratch hull-focused builds so much that I'm thinking I may build a half-hull model of a classic racing yacht. I purchased these plans for the "Shadow," a NY / Newport racing yacht from the late 1800's from the Model Boat Store. Having access to different wood stock will help. Much appreciated!
I would be very surprised if Cygnus does any shipping. It is an actual Ma-n-Pa backyard operation. It is in a pseudo rural part of Va Beach in or near Pungo - a community noted for its strawberries. It has a couple large one story steel pre-fab on concrete slab buildings. I made one visit to see their exotic import stock. Helpful guys. They did not know from Apple - which I am a hawk for. I checked out Purpleheart - they do have that on the hoof. It is about the same color as eggplant - but not as dark - a light purple hull is not my thing - so I can write that species off my list of possibles. Cygnus does publish their price list on-line. Yukon is a lot closer and they are about the same price - they only ship-in I am betting.
I did a Google for hardwood lumber for sale: Bryn Mawr PA US . Did not know where it was - there is a school there I had heard of so the name is not new.
Boy-howdy - that is one big city! I would be surprised if you could see the moon - never mind stars. From the map Wilmington DE is the I-95 start of it - as seen from I-95 Wilmington hit me as one of the most depressing looking places I have seen - obsolete heavy industry -mid 1990's it was. Not quite as Mordor-like as Eastern Kentucky towns - but kind of sad. I think that it will be work to use Google to find a righteous genuine domestic hardwood lumber dealer. There is so much retail level crap camouflage poseing as hardwood dealers. It will probably take a bit of driving the find a real hardwood dealer. I think they are closing the mail order trap and cranking up shipping costs to usurious levels now that we are addicted and local retailers have been starved to extinction. And wood is heavy and diesel is rapidly increasing to its actual environmental cost.
4x4, 8x4, 12x4 round from the mill lumber - needs to be planed top and bottom to get it to track well thru a big bandsaw or 10" tablesaw. It does not require the loss of 1/8" on each face that a commercial mill will take. But - being your own sawmill is tool heavy. Taken as a whole, it is much more economical and freeing than buying finished stock on-line. The initial tool cost is high but that is one and done. Unless you use Lennox bi-metal blades or the equivalent - bandsaw blade costs can eat you up - plain steel that is - the normal low cost ones have way too much set - the thin WoodSlicer type dull quickly and cannot be resharpened. Carbide is more economical than steel - resharpening is not practical for an individual -it is hype. Bimetal is about twice steel but much less than carbide and lasts about half as long.
I advise that you stick with domestic species for your stock. Hard Maple, Black Cherry, Yellow Poplar, clear Pine. There are others that are really excellent - just not commercial. You and a chainsaw can get some good stuff - dangerous if you have had no or poor mentors for how to use that tool. A city that large should have no shortage of tree service companies that may even give your useful species.
Pear - the Pear that you encounter here is Pyrus communis - if steamed it is Swiss Pear. It is a European species. I am guessing that is considered a weed in its natural range. The fruit is small. It may be the root stock for grafted dwarf eatable pear varieties. It is a premiere model wood. It is also too expensive to be practical in North America. Black Cherry is our substitute. What we give up for something that is 1/5th - 1/10th the cost is a wood that is not as hard, with a bit more noticeable grain. But wonderful in its own right. It is not so wonderful that a European should pay the inflated import costs to use it.
We have a Pear that may be even harder - the color is bit different - more difference in grain - it is Fast growing so the bands are wide. This is the Asian import street planting Callery pears. Bradford is the most common. It is now see as an aggressive invasive species. The Suits want it killed off. It should be easy to get from a tree service after a serious wind storm - gets lots and lots - seal - billet - debark - air dry - good air circulation - no rain - off the ground -because - you know - termites and carpenter ants.
Looks like you have caught the addiction that we are trying to spread at The School. A bit like a blind man with a stick as we figure it out.
If it's difficult to find a local wood supplier, I've had good experiences buying from Ocooch Hardwoods and have found their shipping costs reasonable (at least for the small quantities I've purchased). They offer both dimensioned lumber and thicker pieces. They don't have pear, but they do have a pretty wide variety of domestic and exotic woods, including poplar, cherry, and maple.
Ocooch Hardwoods looks like a great resource. I am learning that wood costs less the more you purchase, so wondering if I should stock up a few board yards of basswood and pine stock for the long haul. Plus they're in the U.S. so shipping will be minimal. Have you done a half-hull presentation model (with wall mount)? They look like fun and I just picked up design plans for the 1800's yacht the "Shadow" from Model Boat Store. Wondering if the lifts used are generally stained to show variety or if one relies on different colored woods, like cherry or mahogany? I'll check out some build logs on Sos.
I have done a framed half-hull model before, although not with lifts. I did the NRG 18th-Century Merchantman Half-Hull kit a couple years ago as a way to learn planking. I had a build log on MSW, but it's of course been vaporized. I may try to repost it soon. Half-hull models, whether planked or made of lifts, are a great way to highlight hull forms.
Jaager - A fellow at the Independence Seaport Museum boat shop told me that he sources his wood in Lancaster County, Pennsylvania, which of course makes sense because it is Amish country. The Amish nearby here are known to be great woodworkers. Mennonites also. This shop in Lititz PA looks like they carry a nice assortment of woods for modeling. It's about 90 minutes away and near a place that makes great pies!
I would not buy slabs. I do not build furniture and I guess that there is a premium price. The sawyer has gone to extra lengths to get a raw edge - something that is the opposite of what I want.
The Hard Maple has "interesting" grain. I want the straightest and most boring grain possible.
I may well be an outlier but I would never use Basswood - it is just not crisp. If you paint and use Acrylic water base paints, there is a real probability that the water will swell an already wants to be fuzzy surface into something that looks like a freshly plowed field when viewed under magnification. I also dislike soft Maple. I think anything in the Cottonwood family is pure trash - it isn't even good firewood. I would ask an Amish source if they ever process Apple. Clear straight grain Apple from an old large tree is about as good as it gets. However my focus is larger scale POF. Doing that involves 10's of board feet.
Jaager - May I ask what types of wood you use for hull planking, frames / bulkheads, and deck.planking? Also, any recommendations for wood stock that presents well when used in making half-hull models and their mounting boards? My preference so far has been to use water-based stains on my builds. I only use oil-based paints when the build specifically calls for it, like my recent builds of the Schuylkill River Dragon Boat and the Sea Bright Dory Lifeboat.
4. Annie Buck build log
Some pics of real Chesapeake Bay deadrise working boats, similar to the Annie Buck. The working area of these deadrise boats seem to be longer and broader than my current build, so I may make the cabin and pilot house a tad smaller to make the ratio between working space and pilot spaces appear greater.
JC - Would you care to show pics of your half-hull build? I'm curious what ship you depicted and what wood stocks you used.
Jaager said "I may well be an outlier but I would never use Basswood - it is just not crisp. If you paint and use Acrylic water base paints, there is a real probability that the water will swell an already wants to be fuzzy surface into something that looks like a freshly plowed field when viewed under magnification."
Basswood definitely has that problem. Before I paint it, I but a few coats of shellac to act as a sanding sealer. I find the that really helps.
You have a beautiful looking ship there. I am looking forward to watching its construction!
Rob
