Bluenose Schooner 1921 - Model Shipways 1:64 by TexBilly
She looks really good. Amazing job on the hull! Are you going to brush or airbrush?
Tom, thanks so much! Not sure which way I’ll go but I’ll probably test a brushed sample first. I do need to eventually get my airbrush going so maybe this hull will be my motivation. :)
OK, some progress as I inch closer to painting the hull before switching to the many projects awaiting me on deck.
I have to admit, I paused a good long time before taking my paint brush to the hull as I'm a fan of that smoothly planed and sanded planking, even if it is lower quality wood. Alas, the BN is painted!
I hand painted the first coat of primer and it did its job to expose what turned out to be light filling and sanding. Probably due to me wanting a bit smoother finish on the second coat, requiring long strokes while also battling fast drying primer, my second coat didn't flow (or cover) very well. Nothing horrible and I would have gotten there eventually - but decided instead to switch to spraying with a rattle can.
Much better! Hey, she looks pretty nice in gray! :cool: I'll let the paint cure for a day and set my sights on the waterline.
View attachment 615638View attachment 615636
She shows her lines with the painted base very nice.
Speaking of hull colors, I picked up two candidates. It's hard to tell in the photo but the "Payne's Gray" is a "blueish black" which I've read mentioned as one of the original colors.
I would guess that this will be a nice color combination, Bill. Looking forward to the outcome!
Regares, Peter
i like your hull color selection The Paynes gray is interesting. I have heard the Bluenose at some point had a very dark blue color. Do you intend to airbrush these? I will definitely airbrush mine. The ones you have would definitely require a lot of thinning to be airbrushed and it is possible that the pigment particles themselves are too big for airbrushing.
I am also wondering if you had a large amount of decking planks left? Finishing up decking I have plenty of spare planks. I also had a lot of spare hull planks left over. I know others have complained that they had just enough.
Rob
Rob
Hi Rob, yes, I was wondering myself just how much that type of paint would have to be thinned. I hope to play around with a few methods this weekend. I do like the look of the dark dark blue and hope I can make it work.
I had some leftover 1/8" wide planks but ran out of the 3/32" wide planks (and borrowed a few from another kit). I probably used more than some due to my hull and deck patterns/cuts. I also used a lot of narrow planks on the hull to fill spaces too narrow for multiple wider planks, while trying to maintain the planking "bands". I also reworked a few small areas on the deck so that consumed a bit more. If I had used full-length planks where possible, I'd say the kit has just enough.
I am what I like to call parsimonious, (the Admiral calls me cheap) so i made sure to be as economical with the planking as possible.
I did not use the band method when planking the hull, that probably saved some planks. The kit I have is second hand and probably old. They may have included more planking material.
Rob
Hi Bill,
Your Bluenose is looking great. When I built my Benjamin Latham I painted the hull with artist acrylics. I brushed it and the color laid down very well. I would think brushing or airbrushing would be determined by how much wood grain you want to see.
Bill
Hi Bill,
Bill
Thanks, Bill! I'm actually a fan of letting the wood grain/seams show through so I look forward to testing it out. I now automatically thin my acrylic paints (sometimes I mix, sometimes I wet the brush) but for a large area like the hull, I'm curious how much you thinned your acrylics? Did put on multiple (perhaps thin) coats?
It's waterline time, which means it's an opportunity to play with toys! Isn't that why we buy so many of them? :cool: Well, I played a bit with the traditional horizontal pencil trick by using a table saw blade height jig I have but then had another thought -my laser level.
But first, some setup is required, regardless of the method.
I first leveled the vise in two directions as accurately as possible. Next, the plan's "baseline" aligns with the bottom of the sternpost so I called that y=0". Since the keel doesn't rest on the baseline due to the position of the boat in the water, I needed a solid measuring point to approximate the keel's rise. I chose the upward turn of the keel toward the bow and from the plan measured a rise of y=0.5". I then set the hull into my vise with the sternpost resting on the bottom of its clamp (y=0), then clamped a 0.5" high scrap of stock in the other clamp. Since the 0.5" rise falls above the clamp, I carefully rested the keel on top of the wood and tightened the other clamp. Plenty stable for this purpose.
Now for the practice run. From the plan and at Bulkhead H (at the great beam) I measured from the top of the stanchions down to the waterline and attached a piece of tape for reference. I chose this relatively center position since the hull is fairly vertical. I then stacked whatever was around to raise my level line to that same elevation. I used the level's "self-leveling" mode so I didn't have to fuss with squaring everything.
I left the laser where it was and turned the boat around to starboard and the landing points were very close to those on the port side so I I guess I did a reasonable job squaring the hull and vise.
I'm pretty happy with the results and think it passes the eye test. I'll play a little more to dial it in but the waterline seems to fall as designed (or close) and at least as good as doing it by hand. Once I'm done practicing, I plan to mark the laser line with a series of pencil marks or pointed pieces of tape, then connect the marks with masking tape. What could go wrong? :rolleyes: ROTF
Overkill? Maybe. Did it save some fiddling and set up? Yes! Opportunity to play with toys? Absolutely!!
View attachment 616131View attachment 616132View attachment 616133
View attachment 616134View attachment 616136View attachment 616137
View attachment 616139View attachment 616140
Playing with toys is always fun, Bill. You have now a leveled waterline.
And I see a nice photo of the Fightin’ Texas Aggie Band behind your BN. I saw a lot of videos of them. It’s on my list to see them ones in real. I also played in a marching band myself. Later in a Brass-Band.
Thanks, Peter, this great hobby provides countless learning experiences and it's always fun to find another "ah ha!" moment.
As for the Fightin' Texas Aggie Band, it means a lot to me that you not only know of them but also correctly addressed them by their official name! As a graduate of Texas A & M, I've expereinced their precision marching many, many times but still watch their videos. As you probably know, halftime at A & M football games is not a time to take a break - Aggies make sure to stay so we don't miss a minute of their great performances. The band stirs up a lot of emotion for me as it takes me back to my years on campus but more importantly because that photo is from 1951 and my late father was a junior clarinet player in the band. There he is below. I chose not to join the Aggie band but I also played (trumpet) in marching and brass bands and orchestras throughout my youth. Thank you, Peter!
OK, let's mark a waterline! Rather than tape or pencil, I decided to use my white marker, which made the job easy and fast (though the extra coffee this morning almost made me run a white streak across the hull :rolleyes: ROTF).
Overall, I'm really happy with the result. I plan to spray the white first so once I'm ready to paint the red and blue, I might need to repeat this in order to define the final boundaries of the white stripe (since the waterline is supposed to be the bottom edge of the stripe). But now I have a repeatable process.
View attachment 616525View attachment 616520View attachment 616521
View attachment 616522View attachment 616524View attachment 616523View attachment 616527
You are literally and figuratively ‘Spot On’ ……. Or is it ‘Dot On’ … ;). It is a option to make the waterline with thin masking tape. It’s one spray action less. But with ‘spraying skills’ a painted white waterline shows the best.
ROTF Spots and dots!
Yep, I've read some modelers go the tape way and I've given it a thought but to your point, I fear the tape and paint wouldn't show as well. We'll see how it goes soon!
I have been thinking of using pin striping tape for the while line on my Bluenose. The tape is very flexible,, thin and comes in different diameters and is easy to apply and adjust if need be.
I used it in the past to represent bands around the mast of the Constitution cross section and it worked out well.
Rob
I'm masking my hull for the white stripe (wider than final width) and was looking for opinions on the BN's final stripe width.
I measure 1mm wide from the plan and there is evidence this scales correctly to the prototype stripe width at about 2.5" wide. And yet, when I lay a test piece of tape at 1mm, it looks awfully narrow. I do like it but worry it might disappear visually at the stern. Then again, I don't want to make it too wide at the risk of it looking odd/out of scale. So, I'm curious if any of you have found a sweet spot for your BN or other ship. Thanks in advance for all opinions!
