Misticque, 1/36 - Build Log by Moreplovac
Ok so the process is like this; first i cut several ropes in 15cm length. Both ends of the rope are stiffed with a line of CA.
For lids that are just that, a lid, with no guns behind, last 2 towards the stern, I just run the rope for the outside of the lid. Inner rope side was glued to the hole, once rope was pulled thru the excess rope was cut.
Drag the rope thru the hole on lid...
Re-glued the hinge leaves if they see them dividing like on the picture above.. this is because I used two sheets of paper, glued together so somewhere glue might not be applied.
Then apply a touch of CA to seal the opening and a rope. Light sand to make all flat.
For the "real" lids, same process but with two knots, one either side of the lid..
Finish with small drop of CA to seal the knot and rope.
Since I had two rivets on both ends, I needed to make sure they are aligned. With cutting the rivets short, I might damaged the rivet and rope will not go thru easily. Fix is just to re-drill the hole, using hand drill and adequate bit size.
Now I will glue lids that will stay closed. I have some weird ideas for guns behind those lids... more to come..
Two fake lids..
Normal lids, with guns visible inside.
I used small clip to keep the rope straight so I can freeze it with a drop of CA, on the rivet exit and enter sides.
Let see how it looks from the inside...
I will work on few more lids that will stay closed and than with work on tightening ropes nicely on inner bulwark.
Happy modelling..
Continue my journey with lid ropes. trying to find the best position for them.... not to be on the way of gun rigging...
Some of my guns will stay fixed, out of an action and few will be in fire ready mode, which might not be historically correct but want to show different ways of guns positions on the ship...
This is when the gun is firing and lids are in open stage, run out..
and this is when guns are housed (gun is still missing)...
Happy modelling..
All gun lids were mounted in open or close position and lid ropes were pulled thru.
Then I started to tight all those gun lid ropes to the ship hull..
The ropes were run around three times and freeze up with a drop of CA glue. Continue to all ropes and then will start with gun rigging... fun part.
Happy modelling...
Thanks Grant, yeah. it is very nice looking model... never done airbrush on wood at this scale so it was nice experiment and learning curve.. The biggest challenge with this kit is lack of instructions, which sometimes does not necessary introduce a problem; rather a solution in the form of your own personal artistic approach. Emphasis is on "personal".
I do have another brand, same ship but in a smaller scale which might come next... for a friend of mine.
Cheers
Working on gun capsquares.
For this I made a simple stamping device... the groove was made in the scrap piece of oak, which will be used to hold the nail whose diameter is half the diameter of the capsquare (sorry not quite sure about correct terms)... On the stamping part, I also made a half groove and this will be used to curve the piece of metal. Light kick with a hammer will make required curvature...
The nail was fixed with few drops of CA.
Here is a first prototype...
OK, so 43 to go.
Happy modelling..
