Misticque, 1/36 - Build Log by Moreplovac
Ok so the process is like this; first i cut several ropes in 15cm length. Both ends of the rope are stiffed with a line of CA.
For lids that are just that, a lid, with no guns behind, last 2 towards the stern, I just run the rope for the outside of the lid. Inner rope side was glued to the hole, once rope was pulled thru the excess rope was cut.
Drag the rope thru the hole on lid...
Re-glued the hinge leaves if they see them dividing like on the picture above.. this is because I used two sheets of paper, glued together so somewhere glue might not be applied.
Then apply a touch of CA to seal the opening and a rope. Light sand to make all flat.
For the "real" lids, same process but with two knots, one either side of the lid..
Finish with small drop of CA to seal the knot and rope.
Since I had two rivets on both ends, I needed to make sure they are aligned. With cutting the rivets short, I might damaged the rivet and rope will not go thru easily. Fix is just to re-drill the hole, using hand drill and adequate bit size.
Now I will glue lids that will stay closed. I have some weird ideas for guns behind those lids... more to come..
Two fake lids..
Normal lids, with guns visible inside.
I used small clip to keep the rope straight so I can freeze it with a drop of CA, on the rivet exit and enter sides.
Let see how it looks from the inside...
I will work on few more lids that will stay closed and than with work on tightening ropes nicely on inner bulwark.
Happy modelling..
Continue my journey with lid ropes. trying to find the best position for them.... not to be on the way of gun rigging...
Some of my guns will stay fixed, out of an action and few will be in fire ready mode, which might not be historically correct but want to show different ways of guns positions on the ship...
This is when the gun is firing and lids are in open stage, run out..
and this is when guns are housed (gun is still missing)...
Happy modelling..
All gun lids were mounted in open or close position and lid ropes were pulled thru.
Then I started to tight all those gun lid ropes to the ship hull..
The ropes were run around three times and freeze up with a drop of CA glue. Continue to all ropes and then will start with gun rigging... fun part.
Happy modelling...
Thanks Grant, yeah. it is very nice looking model... never done airbrush on wood at this scale so it was nice experiment and learning curve.. The biggest challenge with this kit is lack of instructions, which sometimes does not necessary introduce a problem; rather a solution in the form of your own personal artistic approach. Emphasis is on "personal".
I do have another brand, same ship but in a smaller scale which might come next... for a friend of mine.
Cheers
Working on gun capsquares.
For this I made a simple stamping device... the groove was made in the scrap piece of oak, which will be used to hold the nail whose diameter is half the diameter of the capsquare (sorry not quite sure about correct terms)... On the stamping part, I also made a half groove and this will be used to curve the piece of metal. Light kick with a hammer will make required curvature...
The nail was fixed with few drops of CA.
Here is a first prototype...
OK, so 43 to go.
Happy modelling..
Now I am done with stamping the metal parts, just blackening later in the process and started to work on carriage rigging. For this I decided not to use kit provided ropes but instead third party. Ropes from kit are fairly low quality and personally it does not make sense putting so much time, money and customization into kit to be finished with low quality rigging, which is the most visible part of a model. Maybe in the near future I master the skills of making my own rope but for now, some online purchased ropes were used.
End result..
How did I get here? First I build a small jig that will assist keeping carriage fixed while working on rigging.
Then I cut all ropes in correct length and add an eyebolt on one end of the rope. Rope with eyebolt was put in helping hands..
.. seizing was put around it...
... I used polyester rope in darker colour than rigging rope since I like seizing to be visible. Poliester rope get tendency to split when cut so I put a small drop of CA on area were cut will be applied. It is clearly visible where cut was done. I do not care too much about split rope since seizing will make sure no hair is sticking out and a drop of CA will keep all in place.
Then I run excess seizing rope 5 times around the tan rope, and use a small clothespin as a weight, pulling one seizing rope side down..
End result...
Then the loose tan rope end was drag thru the carriage..
Another eyebolt installed with the same process when it comes to seizing..
Once the tan rope was pull back towards the carriage so it stay tight, the seizing was applied, glued, and second eyebolt was moved to helping hand, assisting with 5 rounds of seizing rope around and drop of CA to freeze the seizing. Again, small clothespin was used to assist. End result..
Happy modelling...
Your seizing looks wonderful, but I’ve never seen breeching ropes run through the carriage like that. They usually run through an eyebolt on either side of the carriage and wrap around the corbel of the gun.
If I could, gentlemen... it was common for the French (and a few other nations) to run the breech rope through the carriage - it was an English (and American) practice to rig the guns through eyebolts and around the corbel on the barrel. Having now shared this, keep in mind that my wife assures me that I am often wrong...about most everything... :).
I believe you are correct...
Here is what I have done so far... all breech ropes are completed with a an eyebolt attached on one end...
Now continue adding breech rope to the carriage... here is one carriage, helplessly hanging of one helping hand while I am wrapping up around a seizing rope..
Going back to the French way... here is snippet from Ancre' Xebex monogram, showing pretty much what we chatted about...
And then looking at this picture, I noted that all my guns are not sitting tight in the carriages... So back to the kit instruction...
... here is a part I missed, very misleading... being in tech for a while, got used to correct technical drawings but this one is not quite right. The openings for a carriage wheels is cut in side cheeks and this diagram shows openings in carriage bed. So if not attention is made like in my case, I assumed the side cheeks will be mounted outside of the bed not at the top, which causing axles to fit nicely in the cheeks but the whole carriage is wider that gun, causing guns not to fit tight into... Now I am facing a slight dilemma, should I go with rebuilding from scratch all 18 carriages or blame kit instructions for not being detailed enough?
I think I might just build one prototype and see how it fits into overall ship and go from there... just looking into wider carriage that needed and having guns loosely sits in carriage might not be a good view...
Will see and post updates... Bellow is what continental gun carriage should be like...
Happy modelling..
