HMS Victory by Y.T.- Mamoli - 1:90 scale
Another note. I understand the sail heights are somehow larger than the distance between the underside of the yard it hangs from and the yard below.this is to account for the sail to round off in the wind and to maximize its efficiency. As my sails are hanging in calm, I had to make them a bit shorter for presentation purposes so they do not interfere with structures below the sail.
Front course sail. Reefs are still to be added. The reefs will be the most tedious task with dozens of sails I have to make. The sails will be not furled. They will be hanging in calm. I found it is interesting that per historical records the head rope is about half diameter of the bolt rope. It is not the same size rope around all edges of the sail.
This sail looks great Y.T.! I can tell it´s made of fabric, and the lines ar Painted? I see a lot of work and effor on the details around the perimeter of the sail, amazing level of detail!.
How did you make those tiny perforatiosn tha look perfectly round?
Kind Regards
Eduardo Tubino
This is 1 to 90 scale so those perforations are very small. They were made just with the needle mounted into the pinvise and spaced by the eyeballing. Seams are not painted but drawn with 5H pencil. I got some color pencil. Color is just suitable to draw a seam line. Next sail I will try it on.
I am writing a separate tutorial for how I am building the sails. Here is the link.
Thanks a lot for sharing Y.T. !
iPhone makes disgusting close up pictures. Sorry.
Really beautiful result with those triple blocks Y.T! I can tell you were working as a miniature blacksmith this copper wire to obtain this flat piece. Then is very good painted or chemically blacken?
