Looking great, Zoly. You have made some nice progress!!
Thanks Jim!!Looking great, Zoly. You have made some nice progress!!
Thanks Maarten ,I am not really satisfied with the scarph joints,I might redo them ,they do not fit properly at the joints.Beautiful work zoly, love the scarph in your waterway.
Thanks Knut,I am looking forward to this planking,never did margin planks.Good progress zoly, I like the way you lay the deck, I can't wait to see how this work is done, exciting, thank you.
Thanks Uwe,not sure either but looks good.Very clean and accurate execution - I do not know if the planking was done with a hook scarf joint in the margin plank - looking very interesting
Thanks Shane!!Zoltan, sorry about the flood of likes, but this has been an amazing journey so far and I'm not even a third of the way trough your build log. I only wish I had followed sooner than just now. More likes to follow!
Thanks Mike!!Great work Zoly, keep up the good work.
Hi Don ,I did not ,I have a deck planking plan drawn upZOLY, how do you determine the nibling planks before the other planks are installed. BTW GREAT WORK. Don
Thanks!!Honestly I use them all depend the size and type of work actually working on ,from the flat ,square and round type of files,they are extremely useful tools .Great work Zoly.
Could you tell me what type/size perma-grit files you use and find most useful.
Thanks Michel !The deck planks and the margin planks are teak.Very clear work ! Nice wood.
Thank you Janos,more chores ahead though.Gret job, Zoli!
Janos
Thanks Nigel!! I am lucky that they did not make scarph joints one every single planks LolThat is some serious wood jointing Zolly.My interpretation(which maybe wrong) is that the scarphs are to reduce failure due to keel hogging.As the vessels keel can deflect this causes tension/compression on the deck structure which in turn puts planking fixings under sheer forces.This helps stiffen the structure and prevents failure of the fixings.This is quite common with English practice as you do not have binding strakes in the deck structure like ships from France.
Kind Regards
Nigel
