- Aug 16, 2019
Yes a lots of drilling and a lots of toot picks but you did a good work on them
Well continuing on. I added the black arch and second bit of trim to the transom. Then spent a considerable amount of time attempting to bend the rail that will go over the top of the transom. After five try`s at soaking and bending I got a couple rails that were acceptable ( not easy at 1/16 thick) but have decided to put off gluing them on until a later date, after I have the rail on the bulwarks first. It turns out that two davits will stick out off the stern. They get cut into the transom rail so really I will be able to install the rail in three pieces which will be a lot easier to clamp and glue.
In the meantime I also marked out the water line and continued the painted black below the wales to the waterline.
Now I am planking inboard on the bulwarks on up around the gun ports. After planking the transom inboard and painting it I wasn't really happy with the look. It is to flat because the planking really does not stand out at all and it looks more like a painted wall. So I put on my thinking cap and decided to try painting the planking individually first before installing them on the bulwarks and see if that would give it a more planked than painted wall look. I think it does, not sure if you will like it but I think once the rail goes on it will look great. Ran 600 grit over the planks before painting them. The usual pics...
View attachment 124558View attachment 124559View attachment 124560View attachment 124561View attachment 124562View attachment 124563View attachment 124564
PS: Hope you can appreciate my color coordinated clamps![]()
Thanks guys, I haven't put any thought into the cradle yet. I saw one that was very simple just two rods up from a mount block going into the keel, that looked really nice. I usually try to be a little different so I may look around for some driftwood or beach stone to incorporate into mine. Who knows
Charles were is your Louis log bud I haven't found it. Hope you have both had a good xmas or holiday, the Admiral and i have been having a great time.
I am picking away at several area's on the ship. Working on the main rail but will install it later rather than sooner. I completed the inboard planking, filling in the top fore and aft. Sanded and painted again as I had it looking to ridged. Also working on the forward margin planks for the deck. These I am making out of Pear wood and will have the pear deck planks nibbed into them.
Some pics:
View attachment 125388View attachment 125389View attachment 125390View attachment 125391View attachment 125392
hereCharles were is your Louis log bud I haven't found it.
Happy New year to you. Lots of happiness, health, and joy!
I had similar problem with one side being higher then the other on upper planks, didnt notice the top wales had lowered almost a full width at the bow (...wasnt brave enough to rip it all off though.
Instead I added a small plank to the top from the bow to the 4th bulwark, which i can sand down after adding the 2nd sheer strake to the correct level...wont be that noticeable if at all...as for the wales...theres a 2nd layer added on top of the first, then painted black to the waterline.
Just have to make sure that those two top layer's (strake / & wales) are correct then its all golden )
I'm following this build btw best I can...2nd sailing kit ive done so the log your doing is much appreciated, I thank you for it.
