Hi Max,
I am delighted that you found and are enjoying the forum. I love to hear the excitement and enthusiasm in your building. It reminds me of myself of years ago. If you want to caulk your planks, I suggest to just use a simple regular soft pencil lead.  Just run the pencil lead down one side of the planking strip (and this is for the deck only).  You might think that it is not enough, but you will see that it will be. Sometimes, less is more.
If you use a stain or oil, then please be careful.  My opinion is that I have seen models that were soaked with shellac or some type of lacquer that did not look natural.
Think of a real ship. The real ship often had a dull flat paint on it. For a stain, I have always used something like Minwax golden oak or Minwax natural stain.  If and only if I were to use a satin finish, it has always been Minwax polyurethane "satin" finish. It adds such a small amount of luster that it leaves the wood still natural.
Ok, so, I know I am getting way ahead of your game right now. Please do not use a glossy finish.
Key Point #1: Hot water is your friend. Use hot water (even running the plank back and forth under running hot water as you carefully bend the planks)
The large flat strips that follow fore and aft that you were having problems with the alignment...what are those for?  Are those for just stability, or are they going to be used for the backdrop to mount the cannons to?  I was wondering if those flat strips were preshaped to follow the "sweep of the hull". I can not tell.
Key Point #2: Make 100% sure your hull is straight.  Turn the FRAME upside down on a flat surface. Look and see if all four corners have the same measurement to the flat surface. You do NOT want to have any warp. Or very very little warp. Why?  These small errors of warpage ADD UP to be a larger problem down the road.
Key Point #3: When you are at the part where you fit the (assuming a false deck) usually, you will have a false deck solid plywood that attaches to your bulkheads on top. THen your deck planking glues to this false deck. Why am I bringing this up? Well, this is also a problem that I see often. Make 100% sure that your Cannons on Deck, (the Cannon barrels) will LINE UP with your Cannon Port Lid openings on the DECK. I have seen many models that the Cannons (Barrels) on the Deck did not line up good with the Deck Cannon Port Frame Openings and the Cannons had to point a little downward. Sometimes, it was the opposite, the cannons were pointing upwards for the barrels to push through the port windows.  By study and preparation, you might catch this beforehand. I have seen modelers have to remove the wheels from the carriages so that the Cannon Barrels would fit through the Port Lids on deck. This is mostly a DECK problem.  You can MOCK up this situation by assembling one cannon carriage and barrel and placing the assembly on deck. How is this corrected? Well, I am not familiar with this kit, but most kits will have the BULWARK (which is one piece) that already has the Cannon port lids made for you in one piece. All you have to do is simply slightly raise or slightly lower the Bulwark to accommodate the best alignment of the cannons. Your kit might not apply to this, but I just wanted you to know just in case.
Oh, by the way, thanks for joining the SOS family. It is my desire to make your forum experience a happy and enjoyable one.
Sincerely,
Donald B. Driskell
Founder
