way to go MIKE, really looking forward to this one. Don
Thanks Jim, I usually build three or four frames at the beginning and while the glue is drying on those, I cut parts for the next set, no down time. You can produce quit a few frames this way in a week or so.That's a lot of frames for cross-section, Mike!! Looking very good!
This rockwell f 30 lookes like a great "small" triangle sander. I will browse for it in the EU.This is the power tools I use on the inside. The Rockwell F 30 is my favorite for the rough work, the drum and pen sander take care of the small areas the Rockwell can’t reach. After the lining is installed, I use fine grit paper and hand sand the inside.View attachment 125752
to be honest - not easy!Uwe: How easy is it to control the cut (depth, straight and level etc.) when using the blades in the tool?
