All this talk and measuring my Royal Caroline has got my fingers twitching again, but I have to clean up my hobby table first,
best regards John,
best regards John,
But it looks just the same,Dear John (@neptune ),
The aft deck is perfect now. Sorry for the silly mistake.
Do you man "the same as your RC"? Then yes, I got to this level! But it is different from what I had before...But it looks just the same,
Yes, it is for LED.The wires you've soldered to nuts, will this be a source for LED light ?, exciting-
Dear John, I am not sure I understood the question, but what I did is:G'day Alex, how much did you insert to the deck before the mast, and will you be moving the hatches forward,
If it is about the Ohm law, I know it from the school...Alex,have you fitted appropriate inline resistors to suit the LEDs?Different colour Leds operate at different voltages and it is critical.See this guide;
Dear @carlosys ,Unless otherwise, the red LEDs work well with a voltage between 1.8v and 2.1v.
Dear Nigel (@NMBROOK ),Alex,have you fitted appropriate inline resistors to suit the LEDs?Different colour Leds operate at different voltages and it is critical.See this guide;
Hi Alex, I have the English parts list. I will scan it and send it tomorrow.OK, guys, I need HELP.
Neither the manual nor the video provide direct references to the part numbers, and sometimes it drives me crazy.
Does anyone has a translated (or at least e-version in Chinese) parts number list?
The manual itself also would be nice. I got one from @Maarten but it was incomplete.
Dear @carlosys ,
Aha! You think the red LEDs are for 2v? Hmmm. It might explain why they were overheated.
You could be right. At the same time:
- isn't it strange that the ship supplier provided me with 2V LEDs and 3V power unit?
- When I was ordering white LEDs now at Aliexpress they asked me the voltage I needed, and 3V were one of the option. Other options were 5V and 12V, not 2V.
OK, the only option is to buy exactly 3V red LEDs. I see no point in playing with resistors and in burning energy on them.
OK, I will do it.
| Diode type | Typical potential difference (volts) |
| Low brightness red | 1.7 volts |
| High brightness red, high efficiency and low current | 1.9 volts |
| Orange and yellow | 2 volts |
| Green | 2.1 volts |
| Bright white, bright green and blue | 3.4 volts |
| Bright blue and specialized LED | 4.6 |
