I then moved onto the rails on the roof of the cabin, just cheking to make sure all are the same length,
last one still to be cut down to size,
Then there were supposed to be some small beads in the kit, which I cannot find, luckily over the years I have
collected all sorts of bits and pieces and I had some beads of just the right size,
I had to drill them all out to 2mm so they would slip onto the stanchions, I only needed twelve but I drilled
a few extra just in case of breakage,
This is a pic from the video, once they are drilled to the right size, you have to sand one end a little bit flat, you
can see in the pic one at the top and one at the bottom,
