G'day Maarten, are you OK, been a few days since your last post, hope you are well,
Best regards John,
Hi John, yes thanks, here everything is fine.
At the moment too busy with work and other things.
Working on the rudder, see the progress below.
The rudder is made up of two halves of equal thickness from top to bottom.
On the inside I milled space for the tiller.
Then I sanded the inside of the rudder halves to reduce thickness to the bottom and the rear.
I also removed the most rear section of the rudder to replace it with a new strip to cover the glued surface of the rudder halves.
And fitted the strip
Next are the rudder hinges, these are cnc milled casted brass. To my opinion these are too thick and wide so have to sand these down.
After that I hammered them to widen and thin them at the end to give them a forged look.
Soldered the rudder pin into the hinge.
And dry fitting.
Next steps drilling holes for the nails and burnish black.
