Hi all, I have been working on Blandford but haven't updated for awhile. Spring is here and yard clean up has been keeping me busy. Sorry for my down under siblings winter is on its way.
I finished the lower deck, I used a black Brush pen on both sides of the planks to simulate caulking and bamboo tooth picks for treenails. The deck planking is Holy.
I have been working on the main deck, beams are cut and fit. beam 2 and 3 are installed with arm beams, knees and hanging knees. Notches are lining up well after keeping the beams long.
Chain pump dales are installed, made from boxwood. I made a mast wedge for both decks. I just drilled out a piece of dowel and stained them a dye to match the bloodwood, it came out pretty close in color.
Worked on the bits, I made some brass shaves on the lathe. I used a graver to make a grove in some brass rod, drilled and pined in place. I will make the horizontal beam later, installing now would end up in a disaster with my chubby hands trying to finish the deck work.
Made pump cranks wit some brass rod. I hard soldered some tubing on the handle ends to slide over the rod. I could not find any solder paste locally but found some wire solder in a shop and used that. After a few attempts I got the hang of it. Its all about surface prep. Clean and clean again, this is a skill I really wanted to learn. I think the paste would be a little easier to use but the wire worked good, just a little more clean up. What a sturdy joint this makes. Now I want to solder everything.
Here's a few pics, hope you like them.
