Good evening Andy. Wow, looking fantastic and this is your first POF. Great job. Cheers GrantIt has been a while since I have posted but with dog sitting and hospital visits for a friend I haven't had much time to get in the model room
It has mainly involved sanding the hull and fitting the stern timbers
Next job will be starting on some of the internal timbers
Thanks Grant yas it is my 1st POF after building several "normal" builds apart from the instructions this is a great POF kitGood evening Andy. Wow, looking fantastic and this is your first POF. Great job. Cheers Grant
That is an interesting view of the beams and knees not very often seen from below unless you are a sailordue to the fact, that I cut my Granado in two half, we have a very good view from the "hold" up to the beams and the knees
here the hanging knees are not installed - remember this deck is upside down
and now with installed hanging knees (upside down)
interesting also this sketch from Goodwin
You are right about the knees not fitting!Hi, It’s coming along very nicely well done. The knees as they come out of the sheet don’t fit, I cut into them and shaped each one for the correct curve and fit. Don’t worry too much if they aren’t perfect as when the beams and buttons are fitted you can hardly see them then when the next deck goes on you can’t see them at all. Ken
HiYou are right about the knees not fitting!
They seemed to be OK at the bow but are getting worse as I progress to the stern
The only thing that I can think is that the beams are in the wrong place
Thanks for the information yes that would explain the problem on those knees but if you read my previous post things have gone wrong all the way from L2-10 onwardsHi, if you had troubles with the last few hanging knees, that might because you placed them on the wrong side. L2-15 to L2-18 should be placed towards the top (upside down) instead of the normal order. Here's a image from the instructions, please let me know if this is the case.
DO NOT SCRAP! If you feel the current kit is not up to your skills now, you can put it aside. But don't trash it, you will reassess this project sometime later when you gain the experience required.1.. do I scrap the kit and start again maybe with a simpler "normal" kit
Hi so is it that from L2-10 to L2-18, the hanging knees are not fitting the hull shape, and L2-1 to L2-9 are fitting okay?Thanks for the information yes that would explain the problem on those knees but if you read my previous post things have gone wrong all the way from L2-10 onwards
Hi thanks again for the prompt replyHi so is it that from L2-10 to L2-18, the hanging knees are not fitting the hull shape, and L2-1 to L2-9 are fitting okay?
Also regarding the lodging knees (the horizontal ones), are they currently all shorter or longer? or both cases appeared?
These questions will help us better understand your current issues and to solve them.
Hi, Don’t dispair, remember that these knees will not be seen at all once the upper deck is in place, shape them as best as you can then move on, try not to beat yourself up about them, on this deck mine were really no better.Hi thanks again for the prompt reply
Yes L2-10 to 18 gradually get worse in the fitting
The horizontal knees are both too long and short depending on which beam they are fitted to
I am going to try and break the glue on the beams and re fit using the knees as the correct spacer
Depending on how many I break would it be possible to buy replacement parts ?
If placing the last four knees upside down, would it fix the problem of those? or they are already put in that way and still having the problem?Hi thanks again for the prompt reply
Or yes, as Ken kindly suggested, those won't be pretty visible after fitting the gun deck, so you can also choose not the remove the beams and continue. This way you may need to cut the lodging knees slightly for those are longer, and fit spacers for those shorter. I would suggest this as a backup plan, you can try my last suggestion first, if you find it hard then this can be a choice.If placing the last four knees upside down, would it fix the problem of those? or they are already put in that way and still having the problem?
What I suggest to do now is: removing the beams, place them back in order, from front to back, while also fitting the lodging knees and hanging knees in.
E.G.: Beam 1 → lodging knee 1 → hanging knee 1 → beam 2 → ...
This way I believe all the problems will be solved. If you need to replace any parts, please let us know, parts will be free of charge, a shipping cost of roughly 25-30GBP might be required.
Yes I have dry fitted the last 4 knees and they fit wellIf placing the last four knees upside down, would it fix the problem of those? or they are already put in that way and still having the problem?
Agreed. Great advice.DO NOT SCRAP! If you feel the current kit is not up to your skills now, you can put it aside. But don't trash it, you will reassess this project sometime later when you gain the experience required.
Hi Andy, Mine didn’t look much better at this stage, you’ll see that I added a narrow waterway along the beams, to make the fit look better, it masked the irregularities and made the beams look more acceptable. Again remember that these won’t be seen, use this phase as a learning curve for when you do the upper deck. There’s nothing wrong with your building, you will surprise yourself. KenAlthough I have fitted all the carlings every time I looked at them all I could see were the out of square ones so today I have been removing the out of square ones and altering the beams to make them fit better
I know that they will not really be seen after the gun deck is fitted but they HAD to be altered for my sanity..what there is left of it !
I am now wondering if the hull is so far out if the pre cut planking will fit ??
As usual comments and criticism are both welcome
AndyView attachment 451152
