Thank you Phil.Hello Dean,
I admire your work. Have a couple of questions about the bolt heads. I do not see these in the plans, so assume I am missing seeing them or they are from some history or photos of the original ship. How did you do them? Are they just on the back of the frames or both front and back, and are they done prior to securing the the frames to they jig and the keel? I am in the early weeks of building my frames. Can usually do three in a day with drying times and sanding. It is really helpful and fun to have all of the group builds available. There are a lot of talented people on this forum, and you are right at the top. Attached are a couple of my early photos. I started modeling after retiring about three years ago and this will be my fourth ship. Previous builds Caldercraft Mortar, Vanguard Alert, and Mamoli Yacht America. thinking of starting my own build log.
Thanking you in advance for reading and responding if you do.
Phil
The nails on the frames are not part of the kit plans. I added them.
I was going to add treenails, but I saw some bolts on the actual BN 2 build pictures, and decided I liked the look of bolts better.
Some people drill a hole and push or nail in brass wire. I used an old technique that I came up with when I used to build plastic models. I use a straight pin and dip it in glue and dab on to make bolt heads. Then I take a toothpick and put paint on the end and dab on the dried glue dot. It does a good job of representing bolt heads, or rivets.
Anyway, I put them on both sides, as the bolt would have gone all the way through to the other side. And I applied them prior to putting the frames in the keel. Hope that helps.
You should start a build log. It’s a good way to get advice and input from many builders.
